Latest post Tue, Aug 23 2011 11:44 PM by vpcmike. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Aug 19 2011 2:55 PM
    • icemanxts
    • Joined on Thu, Mar 29 2007
    • New York
    • Posts 58
    • Points 845
    AJA IO Express Capabilities
    I'm wondering if anyone using the AJA IO Express could tell me if it's be capable of outputting video both to a 3rd monitor via HDMI and also to a Control Room which would send the video out to a client via SDI.
    1. Would the software between MC and the IO Express work together?
    2. Can the IO Express output through both the HDMI and SDI outputs at the same time with a delay or degredation of quality?
    Thanks for any help.
    MacPro 2 x 2.66 GHz | 8GB RAM | Mac OS 10.9.5 | Media Composer 8.0.0 [view my complete system specs]
  • Fri, Aug 19 2011 3:32 PM In reply to
    Re: AJA IO Express Capabilities
    HD SDI and HDMI work at the same time when running Media Composer with no delay or degradation. It can even downconvert to SD SDI and YUV while feeding a HDMI monitor.
    Edit 1: MC 8.10 + Symphony + PhraseFind • MacPro 6x3.5GHz/64GB OS10.10.5 • Artist Mix & Color • Aja Io 4K • Edit 2: MC 8.10 • MacPro 2x2.66GHz/48GB... [view my complete system specs]
    Rodney Sewell BFS
  • Fri, Aug 19 2011 11:26 PM In reply to
    • hbrock
    • Bainbridge Island, WA
    • Posts 5,586
    • Points 65,025
    • Moderator: MCA Mac
    But MC 5.5 won't work with a G5 Power PC Mac, you need a Intel Mac.
  • Tue, Aug 23 2011 2:35 PM In reply to
    • icemanxts
    • New York
    • Posts 58
    • Points 845
    We're aware. We're doing a system-wide upgrade. Hardware and software. Thanks for the lookout.
  • Tue, Aug 23 2011 11:40 PM In reply to
    • vpcmike
    • Baltimore, MD
    • Posts 1,669
    • Points 20,240
    How are you using the IO Express in a larger environment with referenced (genlocked) decks and equipment?  I don't see any provisions for give the IO Express a genlock signal.
    System #1 - Mac Pro 12 Core 2.93, 24 GB RAM, 16 TB ISIS 5000 System #2 - Core i7 2600k, Windows 7, 16 GB RAM, Quadro 4000 System #3 - Dell Precision... [view my complete system specs]
  • Tue, Aug 23 2011 11:44 PM In reply to
    • vpcmike
    • Baltimore, MD
    • Posts 1,669
    • Points 20,240
    Ignore my previous post - just realized the LTC BNC connectors can be switched between reference and LTC.
