Latest post Sun, Aug 14 2011 6:35 PM by John Moore. 2 replies.
  • Fri, Aug 12 2011 9:12 PM
    • joeydanna
    • Joined on Tue, Jun 8 2010
    • Posts 102
    • Points 1,390
    CC merge
    Can sombdoy explain the CC merge function a bit better to me?
    Im trying to use it, but i must be doing somethign wrong because when i do it, even on a test sequence, nothing happens.
    What i did to test it was took 2 sequences, took the CCs off of one, loaded the non-cc'd verison in the record side, then the cc'd version in the source side, and tried to do a CC merge. shouldnt i bring the CCs from the source over to the record?
    This would be really useful for me to copy color corrects from :30 promos to :15 cutdowns, but i cant seem to figure out how to make it work.
  • Sat, Aug 13 2011 5:15 AM In reply to
    • jmarks
    • Joined on Tue, Nov 20 2007
    • Posts 18
    • Points 190
    Re: CC merge
    The merge only works if you've corrected your shots using either "Tape Name", "Clip Name", or "Master Clip".
    If you've corrected using "Subclip", "Segment", either of the 2 "Programs" (track or segment) or "CC Effect" then the merge will not happen.
    M2 Ultra 14.7.4 MC 2024.12 [view my complete system specs]
  • Sun, Aug 14 2011 6:35 PM In reply to
    • John Moore
    • Joined on Fri, Feb 3 2006
    • Studio City, CA
    • Posts 397
    • Points 4,475
    Re: CC merge
    Sub clip should also work but I never use it.  Beware of Master Clip because sense 3.5 it has been broken and will be ovewritten by a subsequent Clip Name correction.
    Symphony Nitris and Nitris DX 4.x and MCsoft 5.x & 5.5x, MCsoft 6, Artist Color [view my complete system specs]
    John Moore Barking Trout Productions [email protected]
