Hello,
I'm exploring ang starting to use some BCC fx lke the BCC TypeOnText.
Issue #1
For some reason the Text Editor Window stopped showing up. I was just using it earlier. That check box used to launch the editor window, now it became just a check box.
Any ideas?
Thanks.
Ervz Tia | Video ProductionsWM Communications, Asia-Pacific | Philippines
Here's Issue #2:
Sudden missing items. I just recreated this nice 3d text, rendered once but suddenly lost it again.
here's a recent screen grab. I'm now trying via AvidFX again...
Same issue here...
Avid FX worked (extruded text) this time. I wonder what's wrong with BCC.
anyone?
Version of OS - Version of Avid FX ( BCC ) - Version of Media Composer ?
Tomas
AvidFX 5.8.2
Avid MC 5.0
OSX 10.6
(you can check out my system specs below)
Should be 5,8,3 , available at the DL center
The very first version, no good at all, very beta like, please update when you have a chance
Should be one more digit into the end, thats my reason for asking
tikboy: Avid FX worked (extruded text) this time. I wonder what's wrong with BCC.
Ok, just noticed, sorry for beeing blind, what version of BCC
tikboy: Avid FX worked (extruded text) this time. I wonder what's wrong with BCC. anyone?
This difference in the working or not working of the Text Input window is/was a known issue which I reported to BorisFX well over a year ago.
I was noticing it mainly when using Japanese text. I am guessing that you may be using Pilipino or Tagalog. I don't know if Ikom is using French input.
As I said the Text Window, which looks exactly the same in BorisRED and in BCC Filters, was acting differently.The BCC invoked one, did not accept Japanese text at all. The only way to do it was to cut and paste from a text document.
I will check if it has changed lately, but over a year ago it worked as you have described.
The non appearance of the text window was also linked to this problem.
Regards,Douglas
salamat! (arigatou)
tikboy: salamat! (arigatou)
Glad I could be of assistance.
I have heard that BorisFX have the text entry window fix on their list of known bugs to be fixed as soon as possible.How soon is soon? I have no idea.
In the meantime, the workaround is a way over the problem.
Good luck.
