Latest post Fri, Sep 22 2023 1:53 PM by noodleinsoup. 12 replies.
Page 1 of 1 (13 items)
  • Thu, Jun 16 2011 12:01 PM
    • Nnata
    • Joined on Tue, Jul 13 2010
    • Posts 1,026
    • Points 13,690
    Duplicating a clip in the timeline?
    A function I perform often in FCP is to optn drag a clip in the timeline to anywhere I want. Can I do this in Avid?
  • Thu, Jun 16 2011 12:13 PM In reply to
    Re: Duplicating a clip in the timeline?
    Timeline position indicator over the clip you want.
    T key to Mark the clip  I and O.
    Alt C to copy clip into your source monitor.
    Go where ever you want in the timeline, mark in (I key) and overwrite (B key) or insert (V key) edit the clip there.
    Repeat as required
  • Thu, Jun 16 2011 5:46 PM In reply to
    • Nnata
    • Posts 1,026
    • Points 13,690
    'Sigh'. Thanks for your response.
  • Thu, Jun 16 2011 6:17 PM In reply to
    • conleec
    • Los Angeles
    • Posts 1,323
    • Points 17,245
    Why the "sigh?" Much faster than any other editor I've used. With much more control.
    Chris
    MacBook Pro M1 Max (2021), 64Gb RAM, OS X 13.5 (Ventura) [view my complete system specs]
  • Thu, Jun 16 2011 6:21 PM In reply to
    The only thing that I don't like is that the file pastes only on the same track that
    it copied from.
    Desktop
    Asus Ζ690 TUF Gaming WiFi D4|i5 12600K|Corsair 128G DDR4|Asus 3060 12GB|Samsung 980 500GB(OS)|2X1TB Samsung 980 RAID 0|W11 Pro
    Laptop
    MSI Katana GF76 11UE (i7 11800H|Nvidia 3060|Crucial 64G DDR4)|W11 Pro
    NLE
    DR Studio 19|MC 2024.2
    VDIM
  • Thu, Jun 16 2011 7:16 PM In reply to
    • nigelad
    • London UK
    • Posts 597
    • Points 6,945
      Avid Certified User
    Change track patching before overwrite or insert and hey presto.
    NEXIS E4, MC v22.7 on MacOS 10.15.7 [view my complete system specs]
    • tchoupiboss
    • Joined on Tue, Jul 6 2010
    • Paris, FRANCE
    • Posts 23
    • Points 305
    Hey !
    You also can use the Red or Yellow arrows ("paste/replace" or "insert" mode) to select the clip(s) you want to duplicate.
    - Select the mode you want to use. (I have keyboard shortcuts for these very useful functions)
    - Select the clip(s)
    - Press Cmd C
    - Place the blue timeline indicator where you want to paste or insert the clip
    - Press Cmd V. The clip will be duplicated to the same track where it was.
    Yes... I know; Not as simple as FinalCut !
    MacPro Late 2013 - 3,5 GHz 6-Core Intel Xeon E5 - 32Gb memory - AMD FirePro D700 6144 Mo - MC 2018.12.1 - Working fine :-) [view my complete system specs]
  • Thu, Jun 16 2011 7:18 PM In reply to
    sverkalo:
    it copied from.
    It only does that if you use CTRL+C for Copy and CTRL+V for Paste (as if you were using MSWord), if you ALT+C instead, it loads it into the Source monitor and you can patch it to any tracks you like, just as you would any other source clip.
  • Wed, Jul 4 2018 8:04 AM In reply to
    • pianohill
    • Joined on Wed, Jul 4 2018
    • Posts 1
    • Points 5
    Nnata:
    mac: SHIFT+ALT+COMMAND+CLICK/DRAG will duplicate the clip
    for PC i guess you just switch command for control key.
  • Thu, Jul 5 2018 4:07 PM In reply to
    • Schnittskunk
    • Joined on Tue, Sep 20 2011
    • Berlin, Germany
    • Posts 12
    • Points 140
    You can use the Segment Tool and then opt-drag the clip anywhere you want
    iMac 27“ i9 3,6, 40 GB RAM, Vega48, OSX 14.6 - MC Ultimate 2021.12 - BM UltraStudio 4K Mini MacBook Pro Retina 2015 2.8, 16GB RAM, MacOS 12.1 - MC 2018... [view my complete system specs]
  • Sun, Mar 1 2020 5:48 PM In reply to
    • dmehalik
    • Joined on Wed, Jun 10 2015
    • Posts 25
    • Points 275
    This is totally helpful after getting used to this in Premiere... but for me, you need to select the clip in Segment Mode, and begin dragging it BEFORE you hit option.  If you hit option before you start to drag, the lasso appears.
    That being said, I would definitely suggest to folks coming from Premiere to Avid that get to LOVING loading the clipboard in the Source monitor as people have suggested above.  It is extremely handy in a million situations.  You just add "Option" (MAC) to whatever your shortcut for "Copy to Clipboard" is and it will load all clips within your in/out range (for selected tracks) into the source monitor.  You can now insert/overwrite as normal.  You can even examine your new source in timeline view using the Toggle Source/Record timeline button/shortcut.
  • Thu, Sep 21 2023 5:35 PM In reply to
    Showing up a decade later to say THANK YOU!  I've been wondering how to do this for years!
  • Fri, Sep 22 2023 1:53 PM In reply to
    Actually the usefulness of segment mode + option drag doesn't stop at a single clip, it works with a sequence.
    Every now and again I want to duplicate a sequence in the same timeline - making an alternative version that has only slight changes is an obvious case. I use 'select in to out' (it's on my keyboard as a shortcut) and option drag the selected section on down beyond the end of the selection. Done. (other than making those slight changes)
