Latest post Mon, Apr 4 2011 1:14 PM by Jim Allan. 9 replies.
Page 1 of 1 (10 items)
  • Fri, Apr 1 2011 12:57 PM
    • Jim Allan
    • Joined on Mon, Jun 7 2010
    • Oakville, Ontario, Canada
    • Posts 110
    • Points 1,250
    MC 5.5.1 Boris 4.2.2 problem
    I just installed MC 5.5.1 two days ago. Every time I boot up, this message appears:
    "Unable to verify authorization. Please install Boris Continuum Complete from its original distribution CD-Rom."
    ... which I did. But this message still appears. It goes away after I click "ok" about a dozen times.
    Any ideas? Thank you...
    MC v2023.8 with Phrase Find on a 15" MacBook Pro (2017). macOS Ventura v13.5.2, 3.1 GHz Intel Core i7. 16GB 2133 MHz LPDDR3. Radeon Pro 560 4096 MB... [view my complete system specs]
  • Fri, Apr 1 2011 4:07 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,996
    • Points 38,075
    Re: MC 5.5.1 Boris 4.2.2 problem
    Time to upgrade Boris?
    I don't mean to be cheeky, but there was a major code shift around BCC 5 or 6. Now it is part of the AVX 2 universe. Buy the boxed set upgrade instead of the download upgrade and you get BCC 7 and the new Sorenson Squeeze. Well worth the price.
    Have you contacted Boris support? They are very good about handling issues and may have a solution for this. In fact, there is a nagging memory I have that I ran into this years ago and was given a solution.
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
  • Fri, Apr 1 2011 4:18 PM In reply to
    • Jim Allan
    • Posts 110
    • Points 1,250
    I've been doing download-only upgrades all along. Most recently, MC 5.0.3.8.
    Never been a problem before.
  • Fri, Apr 1 2011 4:24 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,996
    • Points 38,075
    I understand. But there have been a lot of improvements in BCC and Sorenson and Avid DVD (does BluRay now) and Avid FX. You get all these for free in the upgrade box. Just saying....
    Burbank, Ca
    www.alphadogs.tv
  • Fri, Apr 1 2011 4:27 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,996
    • Points 38,075
    Here is what you could do. Uninstall Boris. Go to the registry and remove any Boris entries. Restart computer. Install BCC.
    If that doesn't fix it. Boris is your best hope.
    Burbank, Ca
    www.alphadogs.tv
  • Fri, Apr 1 2011 4:28 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,996
    • Points 38,075
    Burbank, Ca
    www.alphadogs.tv
  • Fri, Apr 1 2011 5:15 PM In reply to
    • Jim Allan
    • Posts 110
    • Points 1,250
    Thanks.
    I've also tried to contact Boris.
    It looks like I've upgraded on-line at some point. The plug-ins still appear, and work. It's just this annoying message that keeps poping up.
    It's moment like this that make me realize I hardly use Boris.
    And, I already upgraded to Sorensen 6.5 months ago. Version 7 is already out, and looks like it would save me a lot of time compressing. Funny how these upgrades don't seem to sync up.
  • Sun, Apr 3 2011 1:40 AM In reply to
    • lalittle
    • USA
    • Posts 534
    • Points 7,365
    TCurren:
    Thanks for the link, but it looks like that matrix isn't really comprehensive.  For Avid MC 5 it says:
    Media Composer 5 Win
         Boris Continuum Complete AVX - version 7.
    BCC 6 was in the "Production Suite" that actually SHIPPED with MC 5.0, so we already KNOW that BCC 6 worked with MC 5, but you wouldn't know it from looking at the matrix.
    Larry
    PS.  The Avid downloads page continues to only offer BCC 4.2.2 as the most recent version, which is strange given that newer versions have been available from Avid for quite some time.
  • Sun, Apr 3 2011 9:35 PM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,670
    Hi
    I had the same problem
    http://community.avid.com/forums/t/94664.aspx
    I have contact Boris tech, and 2 days ago they have sent me "new" version BCC 4.2.3 that shoould fix it.
    Just before I got this file I have found a "workaround" for this issue.
    I have a friend that his avid system was crashed (pc hardware problems)
    I took from him his serial number for his BCC5 (also downloaded version)
    I have installed BCC5 over my BCC422. That fixed the error messages.
    Finally I have uninstalled BCC5, so now I have my BCC422 working without any
    error messages.
    MC 2018.4 + MXO2 mini. CPU I7 2600K + 32GB RAM. Nvidia GTX970 driver 388.71. QT.7.7.9 [view my complete system specs]
  • Mon, Apr 4 2011 1:14 PM In reply to
    • Jim Allan
    • Posts 110
    • Points 1,250
    ...just to follow this thread through...
    Marianna kindly sent me a note suggesting that TCurren's line of reasoning was correct, so I decided the best course of action was to upgrade all my third party apps...
    Boris did get back to me and suggested the following:
    "Speaking with Engineering, this may actually be a problem with the way the
    current version of Media Composer addresses itself, making BCC no longer
    recognize it. In that case, the best course of action would be to Uninstall
    BCC AVX 4.2.2, maybe launch Avid just to confirm BCC is completely gone, and
    then reinstall using the installer below -
    ftp://saturn.borisfx.com/supportupload/BorisFX/BCCAVX423Windows.exe "
    ...although he later admits it may not work without the correct serial number.
