Latest post Tue, Sep 3 2013 3:20 PM by 536-KICSW-77. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Mar 25 2011 2:18 PM
    • Graham
    • Joined on Tue, Aug 31 2010
    • Tampa, FL
    • Posts 14
    • Points 400
    Tweaking Vocals With Elastic Pitch In Pro Tools
    If you are using Pro Tools 8 or 9 then you have access to a super easy to use and great sounding plugin called Elastic Pitch. As part of the Elastic Audio engine, Elastic Pitch allows you to make quick tweaks to any piece of audio in your Pro Tools sessions, shifting notes or regions up or down in pitch without affecting the sound quality. Today's video covers making some tweaks to a vocal melody and harmony in a session. Enjoy!
  • Sat, May 28 2011 1:47 AM In reply to
    Re: Tweaking Vocals With Elastic Pitch In Pro Tools
    If I can get the elastic pitch to work it will save me about $900. Wow!
  • Sat, May 28 2011 2:20 AM In reply to
    Very cool. I wonder what range of semi-tones up and down you can go before it starts to sound processed.
  • Sat, May 28 2011 1:15 PM In reply to
    I am getting a message that says "No Elastic Audio Region Selected". I am unable to make the selection like the U-tube vidio illustrates. I am using the Mac Version. I started out with Pro Tools LE 7, and now have ubgraded to LE 8.0.5. My screen does not look the same as what I see in my instructions book. I have never dealt with regions.
  • Sun, May 29 2011 1:08 AM In reply to
    BTW Graham, what's the name of the artist? I like what I was hearing.
  • Mon, May 30 2011 3:22 PM In reply to
    • Graham
    • Tampa, FL
    • Posts 14
    • Points 400
    Hi Larry,
    His name is Keilan. You can download his music from his website: www.KeilanMusic.com
  • Mon, May 30 2011 3:24 PM In reply to
    • Graham
    • Tampa, FL
    • Posts 14
    • Points 400
    Michael,
    You'll need to highlight a portion of audio on the track and then hit Command+E to separate it to it's own region. Then elastic pitch will work on that cut up region of audio.
    Graham
  • Mon, May 30 2011 4:07 PM In reply to
    Thank you, Graham!
  • Tue, Sep 3 2013 3:20 PM In reply to
    Grahm thanks; this information is "WOW!!!!!!"  The power of knowledge is very valuable..........
