Latest post Wed, Mar 23 2011 9:53 PM by DFW Hokie. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Mar 18 2011 7:12 PM
    Canopus
    I've experienced and then searched the forums for issues regarding Windows 7, MC5, and Canopus 110. Is it still true that this mixture does not work together? If not, is this an Avid issue (since my PC seems to recognize the Canopus)?
    Steve
    Avid MC 5.5.1 - Operating SystemMS Windows 7 Ultimate 64-bit - CPUIntel Core 2 Quad Q8400  @ 2.66GHz 55 °CYorkfield 45nm Technology - RAM8.0GB Dual-Channel DDR3 @ 666MHz (9-9-9-24) - MotherboardIntel Corporation DP45SG (CPU 1) - GraphicsSyncMaster @ 1280x800NVIDIA Quadro FX 580 (version 266.35) - DeviceAudioCreative Audigy Audio Processor (WDM) - Operating System MS Windows 7 Ultimate 64-bit - CPUIntel Core 2 Quad - Socket 775 LGATechnology 45nmSpecification Intel(R) Core(TM)2 Quad CPU Q8400 @ 2.66GHzFamily 6Extended Family 6 and Quicktime 7.6.9
  • Fri, Mar 18 2011 7:22 PM In reply to
    • vpcmike
    • Baltimore, MD
    • Posts 1,669
    • Points 20,240
    Re: Canopus
    I remember seeing several posts in the past with users stating that their 110 no longer works.
    System #1 - Mac Pro 12 Core 2.93, 24 GB RAM, 16 TB ISIS 5000 System #2 - Core i7 2600k, Windows 7, 16 GB RAM, Quadro 4000 System #3 - Dell Precision... [view my complete system specs]
  • Fri, Mar 18 2011 8:08 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    Re: Canopus
    vpcmike:
    There are plenty of things that doesn´t work with Media Composer and the firewire bug in Windows 7, ( all ) of the Canopus units belongs to those.
    I was hoping for SP 1 for W 7 to fix this but that doesn´t seem to be the case from reports posted here so far.
    An irritating thing is that it actually worked in an early beta of Windows 7 , a beta WU killed it.
    Tomas, a happy Vista and Canopus user Cool
    Tomas
  • Fri, Mar 18 2011 8:30 PM In reply to
    Re: Canopus
    mjolnarn:
    Would installing the legacy FW driver for W7 several here in the forums have suggested help?
  • Sat, Mar 19 2011 12:37 AM In reply to
    • Radman
    • UK
    • Posts 911
    • Points 10,620
    Re: Canopus
    I am not sure.
    But one should still use the LEGACY driver.
    Works with my Mojo.
    Cheers,
    Radman.
    Win10 64Bit / HP Z800-XW8200 / 5x Quadro M6000. 48 Gig Ram / Cubix Expander 4 / 2x 32TB SAS JMR Raid unit / Avid Artist | Avid Artist DNxIO. 3x 27"... [view my complete system specs]
  • Sat, Mar 19 2011 1:05 AM In reply to
    • lalittle
    • USA
    • Posts 534
    • Points 7,365
    Re: Canopus
    mjolnarn:
    vpcmike:
    Based on my reading about this issue (I have a Canopus ADVC-100), it appears that this is an MC5 issue, not a Win7 firewire bug issue.  There are reports from people saying that they were able to capture from the Canopus units if they used other software (i.e. something other than MC.)  For example, here is a quote from a thread on this very forum:
    "I have Avid MC 5 and I am unable to use the canopus ADVC110 to capture.  The hardware is recognized by Windows 7 64bit and works with Sorenson squeeze and Window Live Movie Maker."
    The quote is from this thread:  http://community.avid.com/forums/t/91347.aspx
    If other software can capture from the unit, then clearly this is not an issue with Win7, but rather an issue with MC5.  In my case, my ADVC-100 is recognized by windows and everything "appears" normal -- it just doesn't show up in MC5.  I have not yet tried to get it to work with other software, however, so I can't confirm what software it works with.  I can only confirm that it does not work with MC5.
    My hope was that MC5.5 would solve this, so I'm wondering if anyone with 5.5 has tried it yet.
    Larry
  • Sat, Mar 19 2011 4:28 AM In reply to
    Re: Canopus
    lalittle:
    Yet another quote in this thread from a Canopus user goes "Tomas, a happy Vista and Canopus user" using the same logic surely means it cannot be a MC5 or MC 5.5 problem. Geeked
    To the best of my knowledge Avid has always require handshaking protocols appropriate to each devices connection method (FW or Com 1) to work as per specific standards as determined by the connection method. (To stop digital copies being made when there is a fair chance that the person is not entitled to make that digital copy) As you may remember Larry from our early forum days  the Canopus 100 has a very simple button technique for overcoming the original commercial VHS copy protection.
    A lot of other software does not require any handshaking standards and this IMO explains why programs like Windows movie maker etc etc have always been able capture from almost anything,
  • Sat, Mar 19 2011 11:31 PM In reply to
    • lalittle
    • USA
    • Posts 534
    • Points 7,365
    Re: Canopus
    AndrewAction:
    lalittle:
    I'm just saying that if it is indeed true that the Canopus units work with Sorenson and/or Windows Live Movie Maker, then it can't be said that these Canopus units don't work with "Windows 7."  The units CAN work in Win7 -- just not with MC5 in Win7.
    That said, I'll fully admit that the issue could be the "combination" of Win 7 with MC5, and the actual "fault" could theoretically lie with either one, or a combination of both.  My point is simply that MC5 is the odd man out here since more than one other application works fine with the Canopus units and Win7 -- it's just MC5 that has a problem.  (On this note, I've read that Adobe Premier also works with these units.)
    I have no idea whether or not this has something to do with handshake protocols as you said, but the Canopus response to this is that these device use standard protocols, and from the 110 onwards, they're "officially" supported in Windows 7.  Given all the evidence, it seems reasonable to look to MC5 as the "most likely" culprit in this scenario.
    Can anyone confirm whether or not this is still an issue with MC5.5 and/or Win7 SP1?
    Larry
  • Wed, Mar 23 2011 9:53 PM In reply to
    • DFW Hokie
    • Plano, TX
    • Posts 272
    • Points 3,670
    Re: Canopus
    I just wanted to add "+1" to the Sorenson Squeeze workflow.
    I capture through an ADS Tech Pyro A/V Link.  The resulting files can AMA into MC5.
    I realize this doesn't address the fundamental question this thread is asking, but it may be a solid workaround for some.
