Latest post Tue, Feb 16 2021 11:03 AM by sezgin.akgunduz. 10 replies.
Page 1 of 1 (11 items)
  • Sat, Dec 4 2010 5:18 AM
    DAE not connected
    Audio suite "DAE not connected", no audio tools.  Reading in the forums about permissions for Common Files/Digidesign/DAE I have all permissions, divers seems to  be there, I wonder if it's the Real Tech audio card that came with my computer.  I have not gone out to select a new audio card yet however everything else is working fine.
    Any ideas what might be causeing DAE not to connect?
    MC 5.0.3
    MC Version: 2018.2 System: PC windows 7 Pro 64 bit, Workstation ATX mid Tower case, MSI Z87-G45 MBoard, 650 watt,Crucial M500 250GB SSD, Intel i7-4770K... [view my complete system specs]
    MC 8.4.5     Built Workstation-Windows® 7 Professional, 64bit,/ Intel® CoreTM i7-4770K processor/ NVIDIA Quadro K2000D 2GB/16GB Dual Channel DDR3 SDRAM at 1600MHz /MSI Z87-G45 Mother Board/650 Watt Power/ Super Multi Blue Writer (LG BH12LS38)/ AVID C-400 for audio interface  Pro Tools MP
  • Sat, Dec 4 2010 7:52 AM In reply to
    • Cagey
    • Vista, CA
    • Posts 319
    • Points 4,120
    Re: DAE not connected
    It would appear that you have a software only config, no Mojo, no DIGI.  I would check device manager and see if you have any driver issues.  If all is OK then do you know if there are third-party drivers loaded for the audio card?  If so then I would attempt to load a Microsoft driver for your audio card. Some third-party drivers cause issues.  You can right-click the device in device manager and click update driver, pick manually select driver, and see if a generic/Microsoft drivers is listed.  If so then choose it to load it.
    Keith
    MC8.6.1, Z420 Xeon E5-2670, 32GB RAM, GeForce GTX 1080, DIGI002, Win 10 Pro 64-bit [view my complete system specs]
    There are 10 kinds of people in the world, those that get binary, and those that don't.
  • Sun, Jan 16 2011 4:33 AM In reply to
    Yes I have software config, I have the manufactor divers, my drivers are from:Realtek Semiconductor Corp. signed by: Microsoft Windows Hardware Compatibility Publisher.
    I guess maybe I should look for a different sound card, what would someone recomment? I do you the midi in but I think I might be able to also you USB in for Midi.
  • Sun, Jan 16 2011 4:46 AM In reply to
    Many users prefer and are very happy with the performance of Soundblaster Audigy cards.
  • Sun, Jan 16 2011 5:00 AM In reply to
    Please confirm the following folder path:
    C:\Program Files\Common Files\Digidesign\DAE | Plug-Ins | Plug-Ins (Unused)\DAE Prefs
  • Sun, Jan 16 2011 7:32 AM In reply to
    In the installed directory I only found this:
    C/ProgramFiles(x86)/Digidesign/Drivers/drivers/
     Doing a search I found this:
    C:\Users\Ron\AppData\Local\VirtualStore\Program Files (x86)\Common Files\Digidesign\DAE\DAE Prefs
    I don't think their installed.
  • Thu, Feb 24 2011 7:02 PM In reply to
    • Jason
    • Los Angeles
    • Posts 31
    • Points 445
    Don't know if you found a remedy for the issue, but I was having the exact same problem and found the resolution from another post:
    Directions to remedy:
    http://avid.force.com/pkb/LegacySearch?DocId=368251
    Vilém
    Avid MC 6.0.1, Win 7 PRO 64bit, Dual X5650 Xeon (2.66GHz 6 core), NVIDIA QuadroFX 4800, 24GB RAM, 10TB storage [view my complete system specs]
  • Fri, Feb 25 2011 3:27 AM In reply to
    Thank you so much problem solved.  I was just about to replace the sound card with an SB audigy might do it any way.
    The path was C:\Users\Ron\AppData\Local\VirtualStore\Program Files (x86)\Common Files\Digidesign\DAE\
    The link post was exactly helpful.
    The DAE/properties/sercuity did not have permissions check for user.
  • Fri, Feb 25 2011 8:37 PM In reply to
    • Jason
    • Los Angeles
    • Posts 31
    • Points 445
    Glad it helped!
  • Tue, Mar 1 2011 10:54 AM In reply to
    • lalittle
    • USA
    • Posts 534
    • Points 7,365
    Jason,
    THANK YOU!
    I just ran into this as well, and found this thread and your link to the solution, which worked for me as well.
    It's interesting to note that I tried searching the Avid Knowledge Base for the solution to this, and even though I found an article that said to refer to the article you linked (i.e. article 368251), there was no link provided, and I couldn't find the actual article that showed the solution. Your link, however, worked.
    I'm also not clear about why this was an issue.  Why would this specific folder require the extra steps to set it up correctly when all the OTHER folders that Avid uses work just fine?
    Thanks again,
    Larry
  • Tue, Feb 16 2021 11:03 AM In reply to
    It worked on windows 10, MC 8.5 version too. Thank you so much.
