Latest post Sun, May 4 2014 5:06 AM by binusriram. 23 replies.
Page 1 of 2 (24 items) 1 2 Next >
  • Thu, Sep 16 2010 8:35 PM
    HELP! Avid Media Composer 30-day Trial expired after less than one day
    I downloaded the 30-day trial last night, got my project set up and when I came in this morning and started working, a window popped up and said "This Trial Has Expired". I've tried calling AVID at least 12 times and get no response.
    What should I do?
    I can't just buy it because my boss wants to try it out first. So far it's making a pretty bad first impression
    There has never been any other AVID software installed on this system.
    Filed under: , ,
  • Thu, Sep 16 2010 8:48 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,739
    • Points 227,800
    • ! Avid Employee
      Moderator: MCA Mac
    Re: HELP! Avid Media Composer 30-day Trial expired after less than one day
    I sent you an email that should get you fixed up.
  • Thu, Sep 16 2010 8:56 PM In reply to
    What version do you have installed?  This was a bug in v5.0.1, and could be what's going on.  We quickly pulled the version from our site due to the issue.  Here's a link to download v5.0.3 - >  http://www.avid.com/US/support/downloads/files/mcsoftcpr/win503 which is the latest version and has the fix.  Other possible cause is if the system clock was for some reason advanced beyond 30 days.
    -Greg
  • Thu, Sep 16 2010 9:33 PM In reply to
    Thanks. That seems to be working. Will that fix it permanently or will I keep having to start up a new project?
    BTW, I installed v5.0.3 from the AVID site last night, so it's the version with the updates.
    Thanks for you help and quick response, guys!
  • Thu, Sep 16 2010 10:01 PM In reply to
    Greg:
    Also, go to the patch center and download and install the 5.0.3.1 patch, or the 5.0.3.2 patch if you are NOT running any additional I/O hardware, like Mojo, Adrenaline or Nitris.
  • Fri, Sep 17 2010 7:34 PM In reply to
    • pgafilms
    • Joined on Fri, Sep 17 2010
    • Posts 2
    • Points 30
    I have a similar problem. I downloaded the 30 day trial and have been utilizing it for two weeks. This morning when I went to log on through the window -- asking if I wanted to continue with the trial -- it indicated that I still had 15 days available. However, after I clicked yes and the program got started, it then said my trial had expired, and I had to close it down. Any help?
  • Fri, Sep 17 2010 7:44 PM In reply to
    I sent you an email with the information they sent me yesterday. It seems to have fixed the problem.
  • Mon, Sep 27 2010 10:29 PM In reply to
    • Piri
    • Joined on Mon, Sep 27 2010
    • Posts 1
    • Points 25
    I'm having the same problem.  Any way you could forward that information for me as well?
    Cheers!
    Piri Miller
    [email protected]
    www.pirimiller.com
  • Wed, Sep 29 2010 12:20 AM In reply to
    • erinmdaley
    • Joined on Tue, Sep 28 2010
    • Posts 1
    • Points 5
    Me as well! Just happened.
    [email protected]
  • Wed, Oct 13 2010 11:54 PM In reply to
    I am having the same problems, the patches recommended in this thread havent fixed the problem, could someone forward the email to me? [email protected]
    Thanks in advance!
  • Fri, Oct 15 2010 1:42 AM In reply to
    • kta
    • Joined on Wed, Jan 9 2008
    • California
    • Posts 145
    • Points 1,900
    I have the same issue, could someone be so kind and forward to [email protected]?
    I noticed it will only occur with old projects, but not with new projects that I create, should the trial work with all, or does have these limitations?
    Thanks!
    Media Composer 3.1.1, MacBook Pro, 4gig RAM, OSX Leapord 10.5.7 [view my complete system specs]
    - Kevin
  • Fri, Oct 15 2010 6:31 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    kta:
    You are quite correct, the trial works this way, it is only possible to work with new projects.
    I have no idea how the trial handles new projects with imported bins from old projects however Wink
    Tomas
  • Fri, Oct 15 2010 12:28 PM In reply to
    Kta:
    Create a new project in MC 5 and copy the .avb bin files from your old project into the new one. DO NOT open the original project directly in MC 5.
  • Tue, Nov 30 2010 11:57 PM In reply to
    • lijesarki
    • Joined on Tue, Nov 30 2010
    • Posts 4
    • Points 35
    I am having the same issue!  Can someone forward me the link as well!!
    [email protected]
    thx!
  • Wed, Dec 1 2010 12:52 AM In reply to
    BUMP
