Latest post Wed, Sep 8 2010 5:49 AM by mjolnarn. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Sep 7 2010 5:21 AM
    • lalittle
    • USA
    • Posts 534
    • Points 7,365
    Now that certified systems use on-board audio (like Realtek) is Audigy no longer needed?
    Over the past several years I've always used a Soundblaster audio card for Avid systems (the most recent of which was an Audigy 2 ZS, which was actually a holdover from a previous system.)  This was due to various problems that were reported when using on-board audio such as Realtek.  I always just used the SB cards without even trying on-board audio.
    With on-board audio becoming the norm these days, however, I decided to check into whether or not this was still an issue with the latest version of Avid.  I discovered that some of the officially qualified systems from both hp and dell now use on-board audio, with some using Realtek.
    Does this mean that using an older Audigy card is no longer necessary with Avid?  It would be nice to not have to continue thinking about using a separate audio card and to just be able to use the on-board audio.  My current motherboard uses the Realtek ALC889, so I'm interested in getting feedback from anyone who might be familiar with this situation.  I'm just trying to avoid a lot of trial and error if at all possible.
    Larry
  • Tue, Sep 7 2010 5:26 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,970
    • Points 70,575
    Re: Now that certified systems use on-board audio (like Realtek) is Audigy no longer needed?
    Using a SB card is not required, or else, it is only required if onboard audio does not work.
    Symphony 24.12, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro T400 [view my complete system specs]
    peace luca
  • Tue, Sep 7 2010 5:44 AM In reply to
    • Saylur
    • Laguna Woods CA
    • Posts 485
    • Points 6,120
    I had to go to a Sound Blaster card because I could not do voice overs with the OB audio.
    MC-6.0.5,MB Asus Z87 Expert 1150 ATX,Intel Core i7 4770 3.4 Ghz CPU,32GB Kingston DDR3 Mem.,Samsung 840 250GB SSD,Win 7 Pro SP 1, QT 7.7.3,PNY Quadro K2000... [view my complete system specs]
    Regards
    Mike
  • Tue, Sep 7 2010 12:48 PM In reply to
    • lalittle
    • USA
    • Posts 534
    • Points 7,365
    It seems like sound cards (i.e. not on-board audio) still offer the advantage of taking work off the cpu, so if I do decide to go with a sound card, does the SB x-fi titanium work okay with Avid?  This seems like the current "main" SB card, and I can't use my Audigy 2 with the new system due to PCI slot restrictions.
    Thanks again,
    Larry
  • Tue, Sep 7 2010 10:47 PM In reply to
    • vpcmike
    • Baltimore, MD
    • Posts 1,669
    • Points 20,240
    Unfortunately, to the best of my knowledge, Avid has never certified sound cards for use.  They specify processors, memory, video cards, drivers, quicktime versions, windows versions, but never sound cards.  I have been begging for this for years.
    System #1 - Mac Pro 12 Core 2.93, 24 GB RAM, 16 TB ISIS 5000 System #2 - Core i7 2600k, Windows 7, 16 GB RAM, Quadro 4000 System #3 - Dell Precision... [view my complete system specs]
  • Tue, Sep 7 2010 11:07 PM In reply to
    • Saylur
    • Laguna Woods CA
    • Posts 485
    • Points 6,120
    mine does Big Smile
    Regards
    Mike
  • Wed, Sep 8 2010 5:49 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    lalittle:
    If you are thinking of using another connection than PCI for your external audiocard I would not recommend that, both PCI-e and Usb connected ones have been reported to not work well
    Tomas
