Latest post Tue, Nov 15 2011 3:39 PM by Robert Goodman . 22 replies.
Page 1 of 2 (23 items) 1 2 Next >
  • Tue, May 18 2010 3:58 PM
    Magic Bullet Looks Still Good on MC5?
    Magic Bullet Looks is our primary styler. I just want to make sure. Will it still work with the latest MC?
    Thank you.
    Ervz Tia | Video Productions
    Filed under: , , ,
  • Wed, May 19 2010 10:15 AM In reply to
    • DylanReeve
    • Auckland, New Zealand
    • Posts 1,680
    • Points 20,605
    • Moderator: MCA Mac
    Re: Magic Bullet Looks Still Good on MC5?
    It's an AVX2 plugin, I think it should work, but I'm not in a position to confirm that at the moment.
    Various systems - including HP Z440 and Z840 workstations Media Composer 2018 [view my complete system specs]
    Dylan Reeve - Edit Geek // Online/Offline Editor // Post Production Supervisor
  • Thu, May 20 2010 4:48 AM In reply to
    Please let us know when you do.
  • Fri, May 21 2010 8:58 PM In reply to
    • Art Riddle
    • Joined on Wed, Apr 21 2010
    • Irvine, CA
    • Posts 29
    • Points 355
    According to Red Giant Software it only works with Media Composer 2.7 or earlier.  Their matrix only lists up to MC3.0.  I have used it on MC3.0  and later though.  I currently run it on MC 4.0.5 on Leopard on one system and Snow Leopard on another.  The only incompatibility I have found is that it does not support 1080P at 23.98.  It splits the frame in half and then crashes MC.  I have to switch to 720P and render it.  This is very annoying since I am rendering at an incorrect resolution.  I contacted their support concerning this and they said they could not test it since they do not have a MojoDX box to support that project type.  As for MC5?  I hope so too since we use Looks on every major project.
  • Fri, May 21 2010 9:39 PM In reply to
    • mmullen
    • Joined on Thu, Nov 13 2008
    • Haverhill, MA
    • Posts 574
    • Points 6,645
    Looks like theri support matrix hasn't been updated in a long while.
    I'd contact their support:  http://www.redgiantsoftware.com/company/contact-us/support/
    -Matt M.
  • Thu, Sep 23 2010 10:56 AM In reply to
    Hello, Can our MC5ers give an update about this?
    I'm trying to contact RedGiant.
  • Thu, Sep 23 2010 12:52 PM In reply to
    • switthaus
    • Cobbs Creek, VA
    • Posts 2,260
    • Points 30,670
    I just quicky opened my MC 5.0.3.1 and put a Looks effect on a clip and it seemed to work as normal.  Don't have the time to really push it around, however.
    Looks Builder v1.3.4
    Scott Witthaus
    Owner/Editor/Post Production Supervisor 1708 Editorial
    http://vimeopro.com/1708editorial/1708-editorial
  • Fri, Sep 24 2010 12:58 AM In reply to
    • Jamie Beedy
    • Joined on Tue, Nov 13 2007
    • Chicago, Il
    • Posts 225
    • Points 2,630
    Had the same question last week, and looking at Red Giants support chart, was no help. woefully out of date. Wrote to support and the response I got from Dave Vieira at Red Giant that Looks and Mojo are both supported. Like Scott, I've installed Looks, and applied a quick effects in V5, and played back some V4 sequences that had Looks effects on them, and so far, everything has worked fine. But, haven't done any in depth Looks yet. But, I'm comfortable in saying everything should be fine.
    jamie
    Avid Media Composer w/ Symphony Option-V8.5.2 / Mac OSX 10.9.5 / Mac Pro 4.1 - 2x2.66Ghz Quad-Core Intel Xeon / 24 GB DDR3 RAM Unity 5.1.3 Unity Media... [view my complete system specs]
  • Fri, Sep 24 2010 1:47 AM In reply to
    salamat!
    (thanks)
  • Fri, Sep 24 2010 7:40 PM In reply to
    • Art Riddle
    • Irvine, CA
    • Posts 29
    • Points 355
    I have had success with MC 5.0.3 and Looks.  I have even solved the rendering issue I have been having with the 1080p/23.98 projects.  I typically place the Looks effect onto filler above my clips to do a color grade of a scene and then I can easily get to my color correction balancing on my clips below.  I found that if Looks is placed directly on the clip, even with a color correction nested below it will render in 1080 now without issue.
  • Fri, Sep 24 2010 8:32 PM In reply to
    • erik1185
    • USA
    • Posts 1,063
    • Points 13,200
    Is anyone using Windows 7 64 bit with Looks?
    Late 2013 MacBook Pro, 2.4 GHz Intel Core i5, 8 GB RAM, Intel Iris 1536 MB Graphics [view my complete system specs]
  • Sat, Sep 25 2010 2:24 AM In reply to
    good to know. iL keep this in mind.
    Art Riddle:
  • Wed, Dec 29 2010 11:08 PM In reply to
    • Walter Riggi
    • windsor, ontario canada
    • Posts 153
    • Points 1,910
    erik1185:
    Same question here... anyone?
    Mac OS X 10.11.6 | 2 x 2.4 Ghz 6-core Intel Xeon | 24 GB 1066 Mhz DDR3 RAM | NVIDIA K5000 4GB | AVID C|24 Console | AVID Media Composer 2018... [view my complete system specs]
  • Thu, Dec 30 2010 5:49 AM In reply to
    • hbrock
    • Bainbridge Island, WA
    • Posts 5,556
    • Points 64,755
      Moderator: MCA Mac
    Might want to ask about Windows 7 on the Media Composer - PC forum.  We're a bunch of Mac users over here.
  • Thu, Jul 7 2011 8:40 AM In reply to
    Hello!
    It's seven months later. I still enjoy MBLooks.
    Just curious about the future of the plug-in. RedGiant seem very quiet about Avid.
