Latest post Wed, Mar 31 2010 7:45 PM by kta. 2 replies.
  • Tue, Mar 30 2010 6:01 PM
    • kta
    • Joined on Wed, Jan 9 2008
    • California
    • Posts 145
    • Points 1,900
    Mixed format timeline - transcode
    Hello,
    I'm working in a mixed format timline. Some of the footage is HDV 60i format, and then the rest is transcoded DNxHD145. In the end, I will need to transcode the entire sequence to DNxHD145 to export, when I do this, will it skip all thecurrent DNxHD145 clips, and only transcode the necessary clips left? Thanks.
    Media Composer 3.1.1, MacBook Pro, 4gig RAM, OSX Leapord 10.5.7 [view my complete system specs]
    - Kevin
  • Wed, Mar 31 2010 3:39 AM In reply to
    • gumbycat99
    • Joined on Fri, Jun 6 2008
    • Auckland, New Zealand
    • Posts 588
    • Points 7,080
    Re: Mixed format timeline - transcode
    One way to do this is to put a copy of your final sequence into a bin by itself. Then from the fast menu on the bin choose "Set Bin Display" and then tick the "Show reference clips" option.
    Now you can see all the clips in your sequence, so sort them according to resolution, select all the HDV ones and transcode those.
    You could also tick the "Rendered effect" box so you can see the resolution of any render files in the timeline. If there are lots of rendered files at HDV resolution you can mark in/out points around your timeline, right-click and choose "clear renders" and then you can re-render the effects after you've transcoded the footage.
    cheers
    Campbell
    8.5 on a mongrel PC, Win 7, QT7.5, Nvidia GTX 970, 16Gb RAM, SSD, NAS for raw media and a Macbook Pro [view my complete system specs]
  • Wed, Mar 31 2010 7:45 PM In reply to
    • kta
    • California
    • Posts 145
    • Points 1,900
    Got it, thanks Campbell. I'll give it a go then when I finish the sequence. That's definitely gonna be a time saver.
    - Kevin
