Latest post Thu, Jan 21 2010 12:02 AM by gumbycat99. 4 replies.
  • Wed, Jan 20 2010 11:20 PM
    backing up XDCam disc contents to hard drive
    I have been handed two XDCam discs and have decided that I want to copy the contents of each disc into it's own Folder onto a hard drive so that I can use AMA and Link to the Volume and have a Bin created for each disc.
    I started copying and all seemed to be going ok, until I received a message saying that Some of the Actions could not be copied because I don't have sufficient privileges.  I checked the disc contents and some of the files are Locked.  I'm unable to unlock them using the Finder Get Info.
    I was wondering if anyone else had advice/experience backing up the contents of an XDCam disc to a hard drive?  Have you ever encountered the files being locked?  Should I not be using Finder to copy the disc contents?  Why?  Is there another better method for preserving the disc structure/contents and making a backup?
    I'm using MC v4.0.4 (Mac) and the PDW-U1 Reader.
  • Wed, Jan 20 2010 11:32 PM In reply to
    • gumbycat99
    • Joined on Fri, Jun 6 2008
    • Auckland, New Zealand
    • Posts 588
    • Points 7,080
    Re: backing up XDCam disc contents to hard drive
    There's an old discussion on this here but near the bottom it looks like someone did have success using a U1 drive. The record tab on the disk isn't flicked is it?
    I was unable to copy using a V1 reader, but with the camera I was able to do it. Since the camera isn't available all the time I changed my workflow and gave up using AMA permanently for the disks, just to open them and consolidate the media.
    Good luck.
    Campbell
    8.5 on a mongrel PC, Win 7, QT7.5, Nvidia GTX 970, 16Gb RAM, SSD, NAS for raw media and a Macbook Pro [view my complete system specs]
  • Wed, Jan 20 2010 11:35 PM In reply to
    • gumbycat99
    • Posts 588
    • Points 7,080
    The alternative way to backup your data would be to consolidate the  clips to a media drive, then export an aaf of the bin with the media in a folder that you could archive on a separate drive.
    Or keep the disks in a fireproof safe like we do!
    cheers
  • Wed, Jan 20 2010 11:47 PM In reply to
    Good ol' Bob Russo came through for me...  here's his response.
    "For whatever reason, on a Mac with OS X, locked files can’t be copied to Unity, its always been that way.
    Copy the Disk to a local drive and unlock the files using the finder. You’ll then be able to copy the files.
    Or, use a computer running Windows."
    I didn't include the bit about it going to Unity here because I honestly didn't think it would make a difference.  Shows what I know.
  • Thu, Jan 21 2010 12:02 AM In reply to
    • gumbycat99
    • Posts 588
    • Points 7,080
    Cool. Sounds like another one of those gotchas that you never expect with computers. Glad the solution came through, thanks for posting it.
    cheers
