Latest post Wed, Jan 20 2010 7:43 AM by camoscato. 18 replies.
Page 2 of 2 (19 items) < Previous 1 2
  • Wed, Jan 20 2010 1:12 AM In reply to
    • gumbycat99
    • Joined on Fri, Jun 6 2008
    • Auckland, New Zealand
    • Posts 588
    • Points 7,080
    Re: Avid sequence to FCP...
    Ah! The XDCAM EX Clip Browser from Sony actually converts them to MXF files that Avid can read. But it's a bit late for that, perhaps. Although you could actually test this as a workflow.
    If you got the Clip Browser software, and used the Export MXF for NLE function then it makes files that Avid imports, the same as it would have imported the original files. So in theory you might be able to create new MXF files, then select a clip in your bin, choose Batch Import and change the file location to the new MXF file that doesn't have the watermark. Hopefully it will import correctly and you'll have the hi-res version in the sequence on your Avid.
    Aside from that, if it is a short film, then my approach would be to get a friend and a few beers (not too many!) and sit there with a print out of your edl and recut it in FCP from the quicktime files you have. Not the best way to spend an evening but if you have some good company it'll be done before you know it.
    Sometimes you can spend more time looking for a neat solution than it would take to just use a hammer!
    Good luck with the film!
    cheers
    Campbell
    8.5 on a mongrel PC, Win 7, QT7.5, Nvidia GTX 970, 16Gb RAM, SSD, NAS for raw media and a Macbook Pro [view my complete system specs]
  • Wed, Jan 20 2010 1:52 AM In reply to
    • daktulus
    • Posts 960
    • Points 13,930
    Luca:
    I had problems with BLKDOGs censorship also. I think he confuses "professional" with "narrow minded" sometimes which is not professional at all. No offense, but I wish we could be more professional here, which includes an understanding of the arts. Because if you are not just a data wrangler, this is what most of us editors are: artists.
    i7, Nvidia 860M, 16GB RAM, 500GB SSD, MC 7.03. Dell Precision M90, Core2Duo 2.16Ghz, FX1500, SATA 7200rpm, MC 4.05. Dell650, 2.8Ghz, 3 GB RAM, FX500, 5... [view my complete system specs]
  • Wed, Jan 20 2010 2:28 AM In reply to
    What version of Media Composer were you using?  If anything v3.5 or later, the EX files could've been brought in using AMA with no conversion whatsoever.  But barring that as an option Campbell points out that XDCam Clip Browser produces Avid compatible files (and it's free)
  • Wed, Jan 20 2010 7:43 AM In reply to
    daktulus:
    Let's keep this thread on topic.  If anyone has any problem with an individual forum member, work it out with them in a PM.  If anyone has a problem with a moderation decision, contact the moderator by PM, and if you're still not satisfied, contact Marianna Montague by PM.
    thanks,
    Carl
    Media Composer 2024.2 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
