Latest post Fri, Dec 18 2009 10:00 AM by Evan Schiff. 3 replies.
  • Mon, Dec 14 2009 5:07 AM
    • filmstl
    • Joined on Mon, Feb 19 2007
    • Posts 16
    • Points 170
      Avid Certified User
    Locked P2 card content and the mac
    I need a bit of help here.  I am running Avid Media Composer 4.0.2 on 2 X 2.66 dual core Intel Xeon.  We also have a LANShare.  The OS for the mac is Leopard. When I connect the Panasonic HVX200 to the system through USB, all the files on the card are locked.  This is not allowing for a smooth copying into our LANShare.  The copying stops and gives a permission message, but leaving some files in the LANShare that are hard to delete.  Any advice? Thanks!
  • Mon, Dec 14 2009 7:17 PM In reply to
    Re: Locked P2 card content and the mac
    usually don't send someone off-forum for advice, but here's some P2 love from none other than Barry Green himself...
    http://www.dvxuser.com/V6/showthread.php?t=118672
    2 systems: Mobile: 16-inch Macbook Pro 2.4GHz 8-Core i9 w/64 gig RAM, 2TB SSD, OS 10.15.3 running MC 2020 Beta Legacy - MC v5.5.4, OS 10.5.8, QT 7.6, on... [view my complete system specs]
  • Tue, Dec 15 2009 4:01 AM In reply to
    • filmstl
    • Posts 16
    • Points 170
      Avid Certified User
    Thanks Bill. I will check it out.
    Jorge
  • Fri, Dec 18 2009 10:00 AM In reply to
    • Evan Schiff
    • Los Angeles
    • Posts 121
    • Points 1,475
    If you're left with locked files, btw, you can run a command similar to this in Terminal (just change the path to point to where your locked files are):
    chflags -R nouchg /Volumes/P2_Cards/Card1
    I wouldn't recommend running this on the card itself, of course, but it's a handy command if you have local directories of locked files you need to move/delete.
    --Evan
