Latest post Thu, Dec 3 2009 11:40 PM by fredman1138. 74 replies.
Page 1 of 5 (75 items) 1 2 3 4 5 Next >
  • Fri, Nov 27 2009 4:03 AM
    Film and 24p settings missing? MC 3.5
    Hello,
        I have MC 3.5 and am trying to capture some stuff that was shot at 24p.  I don't want to work in a 29.97 timeline, I would like to keep it as native as possible.  I can capture the footage for about 2 minutes and then I get an error, and upon playing back the media in AVID is seems to get slower (at least he audio does) as the time goes on.  The video is also displaying at 29.97 frames.  From searching around I have read that many people mention adjusting the pulldown upon capture in the "film and 24p" settings, however I cannot find this settings menu anyway in AVID.  From what I understand this can help AVID caputre the footage correctly so it stays in "24p" and not jumping to 29.97 thus screwing things up.  I look forward to your responses guys....
  • Fri, Nov 27 2009 7:33 AM In reply to
    Re: Film and 24p settings missing? MC 3.5
    Can you be a little more specific? What is your source footage, on what format is it, are you using any type of Avid hardware with your MC, what type of connection are you using to go from your source device into the Avid, what project type are you in / did you create?
    Media Composer Symphony | PT Ultimate | Win11 HPZ | OSX MBP [view my complete system specs]
  • Fri, Nov 27 2009 10:00 AM In reply to
    • mvegas
    • Posts 1,555
    • Points 17,980
    When launching either a 29.97 Matchback project or a 24P project there is a small dialog box notating filmtype right below
    the project type.  if you do not check it you will not see the film settings in the project's settings list.
  • Sat, Nov 28 2009 12:12 AM In reply to
    Ok so I found the Film and 24p settings by creating a new project and checking the "film" box.  However I'm beginning to think I am screwed and this is a lost cause.  I still have no way to access the pulldown settings to be able to properly import the clips I need to use.  I am using 3.5 Software only and I am beginning to think that I am going to need some kind of hardware based system to be able to set pulldown/pullin in when capturing video.  I caputre via FireWire (currently captuing footage shot on a Canon HV30 @24p on a Canon XH-A1.  It wil capture with 24 frames but will quickly get an error message about 2 minutes into capturing.  Its obvious that AVID doesnt know what pulldown settings to apply to the footage to correct for the frame layout, the sound is off by about 20% or so and gets progressively slower.
    Do I need a hardware based system to be able to manipulate pulldown on capture?  and if so is anyone aware of third party applications that I can capture through, apply (or remove if necc) the pulldown and then bring the clip into Avid.  I have pretty much yanked out the rest of my hair on this one.  I need some help here guys.  If you have an answer please let me know!
    Thank you kindly.
  • Sat, Nov 28 2009 3:40 AM In reply to
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,265
    Hey,
    after you've made a 24p project, have you gone to the "Film and 24p" settings under the settings tab in the lower left corner of Avid (where the bin selection  and effects tab are)? There, you can set pulldown and cadence.
    If you have footage that's already been captured, then promote a motion effect and select  source with 2:3 pulldown and then selct "detect" for the cadence.
    A great third party software  to use to remove pulldown is DVFilm Maker
    http://dvfilm.com/maker/index.htm
    I hope that helps somewhat.
    Salud!
    P.S. Also, there is Raylight MXFX
    http://dvfilm.com/MXFX/index.htm
    HP Z800 MC 8.3, Adobe CC, Windows 7 Ultimate 64-bit SP1, 2 Hex Core X5650 @ 2.67GHz, 48Gigs Ram, NVidia Quadro K4000, Sandisk Extreme 240 gig SSD System... [view my complete system specs]
  • Sat, Nov 28 2009 4:30 AM In reply to
    Thats what I wanted to do, but in the film and 24p settings tab all I see is the following options....
    Master Default Film Type
    Master Default Edge Type
    Ink Number Default Type
    Ink Number Default Edge Type
    Auxillary Ink Default Film Type
    Auxillary Ink Default Edge Type
    I see nothing about pulldown cadence.  Is this because I am software only?  Or am I missing something.  Also I tried removing the pulldown using TMPGEnc and successully created an apparent lossless clip that AVID now sees at 23.976 (23.98) fps however when i try to import the resulting .M2Tfile I can an error from Avid citing a mismatched format.  So I dont know what to do....
  • Sat, Nov 28 2009 4:51 AM In reply to
    by the way I'm running MC 3.5 if that matters
  • Sat, Nov 28 2009 6:07 AM In reply to
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,265
    Do you see this when you pull up your settings? Also, it doesn't matter if you aere on 3.5 or 4.04. Did you choose 23.98 also?
  • Sat, Nov 28 2009 6:30 AM In reply to
    My current project settings are
    1080p/23.976
    Raster set for HDV 1440 x 1080
    Here is what I see when I click on the Film and 24P settings, I wish I had that pulldown option....
  • Sat, Nov 28 2009 6:35 AM In reply to
    After I tried using TMPGEnc to employ pulldown removal I do get a clip that Avid now sees as 23.98 (I know this because when I try to import into a 60i project, it tells me the edit rate doesnt match (23.98) however when I try to import that clip into my 1080 23.976 project I get the following error.  This is driving me waaaaaaayyy past crazy....
  • Sat, Nov 28 2009 6:41 AM In reply to
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,265
    Hmmmmm,  go to your format tab and choose 720p/23.97 and see if the Film and 24 setting come up.
  • Sat, Nov 28 2009 6:43 AM In reply to
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,265
    Have you tried the Motion effect in Avid? and Promote it to see if you can remove pulldown that way?
  • Sat, Nov 28 2009 7:19 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,971
    • Points 70,590
    See if THIS helps.
    Symphony 24.12, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro T400 [view my complete system specs]
    peace luca
  • Sat, Nov 28 2009 8:25 AM In reply to
    havent tried the motion effect yet.  I was trying to avoid that due to how time consuming the render will be.  I don't know why this isnt working, nor do I know why I am just missing some settings here.  This problem just gets lamer and lamer...
  • Sat, Nov 28 2009 8:46 AM In reply to
    I switched the project settings to 720 23.976 and now I get the following screen.   An added option of Video Pulldown Cadence has appeared.  I went to try and capture and all I got was a garbled mess.  With these options availalbe on this project setting does this help me at all?
