Latest post Mon, Nov 30 2009 2:41 PM by AKA Dave. 15 replies.
  • Wed, Nov 11 2009 4:27 PM
    • AKA Dave
    • Joined on Mon, Dec 3 2007
    • Raleigh, NC
    • Posts 228
    • Points 2,795
    Holy crap Windows 7 worked!
    So my old OS was giving me some issues (not with MC) after I upgreaded an application so I took a chance and loaded Windows 7 Professional in its 64-bit version.  I was about to pull the trigger on upgrading to MC4.0 this week instead of next month but decided to load 2.8.4 and see what happened.  I'll be damn if it didn't just load right up.  I have not done any extensive testing or cutting yet but old projects play and a few quick edits seem to work just fine.  It looks promising.  The other nice thing is that there were no audio issues on launch like I had before I found a working driver for the IDT audio on the M6400.  It also seems to be getting along well with IE-8.  I'll keep an eye on things and post back if I run into any issues.
    Dave
    P.S.  I edited the post title to help those searching for Windows 7 info find this more easily.
    Former title was "Holy crap it worked!"
    MC 8.4.0 with Symphony Option. 27 Inch iMac. 3.5 GHz i7, 16GB RAM, NVIDIA GeForce GTX 780M 4096 MB, OS X 10.10.3 - MacBook Air i5 4GB RAM [view my complete system specs]
  • Wed, Nov 11 2009 4:41 PM In reply to
    Re: Holy crap it worked!
    Thanks Dave. Please keep us informed of any issues you may run into.
  • Wed, Nov 11 2009 5:39 PM In reply to
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,265
    Windows 7 is working pretty gravy over here too. The only issue is the event viewer is saying aspi32.dll, under the wow64 driver folder, is incompatible and keeps blocking it. It is installed by AVID media composer, because when I uninstall  MC 4.03, aspi32.dll disappears. Also, if you just delete aspi32, then when you click on the MC shortcut  a pop-up screen appears with "avid is now configuring".
    However, I don't see it affecting anything with the mechanics of MC 4.03 and I thought there might be an error with importing tracks from a CD 9from the cd/dvd drive, I've read that some where) into MC, but that worked without a hiccup. AVID fx, sorenson, Sonicfire, BCC, Magic Bullet, After Effects CS3...I could list a a few more, but I'l stop - it's all working with no crashes! Just let me stay in this Shangri-la for a while more, before someone crashes it down for me.
    And, as I said in another post, Windows 7 was an easy install and I haven't had any other issue any of my other post prduction software. But, I'm only running MC software with no additional hardware...SAlud!
    P.S. Now if only someone could answer this question for me Big Smile:
    http://community.avid.com/forums/t/77260.aspx
    HP Z800 MC 8.3, Adobe CC, Windows 7 Ultimate 64-bit SP1, 2 Hex Core X5650 @ 2.67GHz, 48Gigs Ram, NVidia Quadro K4000, Sandisk Extreme 240 gig SSD System... [view my complete system specs]
  • Thu, Nov 12 2009 2:16 PM In reply to
    • AKA Dave
    • Raleigh, NC
    • Posts 228
    • Points 2,795
    So after some more goofing around with MC and Windows 7, I found one small issue.  When I go to use the Audio Suite I get the following error message.  "User privileges insufficient to start a low level driver."  The of course the DAE failes to load.  As I am the only person using this computer and am signed on with Admin privileges, I am a bit baffled.  Any thoughts?
    So far this is the only thing that I can find....knock on wood.
    Dave
  • Thu, Nov 12 2009 2:19 PM In reply to
    Possibly a permissions issue. Check this procedure. Hopefully it's the same for Windows 7.
  • Thu, Nov 12 2009 3:08 PM In reply to
    • AKA Dave
    • Raleigh, NC
    • Posts 228
    • Points 2,795
    Hi Larry,
    Yeah I tried that.  I even updatd the driver from DELL and am now using that instead of the Windows povided driver with the same good result but still no dice on the DAE. Luckily I don't use it that much.
    Dave
  • Sat, Nov 14 2009 11:49 PM In reply to
    • AKA Dave
    • Raleigh, NC
    • Posts 228
    • Points 2,795
    Re: Holy crap Windows 7 worked!
    Ok.  Just rean into another snag here.  I've been working with media that I've already had loaded so I never plugged in the MOJO SDI.  Windows is asking for a digitally signed driver from AVID.  It won't accept the old one for some reason.  I have searched and no luck finding one if they even exist.  Can someone point me in a direction here so I can continue working the kinks out of the new OS?  I am ordering MC 4.0 tonight if it matters.
    Dave
  • Sat, Nov 14 2009 11:59 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    AKA Dave:
    So, to summarize this    " holy crap, W7 doesn´t work "    I am sure of that Avid will tell us when it works ...
    Tomas
  • Sun, Nov 15 2009 12:03 AM In reply to
    • AKA Dave
    • Raleigh, NC
    • Posts 228
    • Points 2,795
    I am not ready to give up on it just yet.
    Dave
  • Sun, Nov 15 2009 2:06 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,821
    • Points 63,225
    With Vista you can hit F8 during the boot and select an option to allow unsigned drivers. I don't know if this is true for Windows 7.
    I have to agree with the spirit of Tomas' reply. This thread should have been 'Holy crap Windows 7 sort of works with a very contrained set of tests and limited hardware support... your mileage may vary'. Stick out tongue
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sun, Nov 15 2009 4:38 PM In reply to
    As I've said many times, an unqualified system may work initially, but the real test is stability and reliability in the long run - no guarantees.
  • Mon, Nov 16 2009 4:37 AM In reply to
    • AKA Dave
    • Raleigh, NC
    • Posts 228
    • Points 2,795
    Larry Rubin:
    Very true.  While my initial experience was pretty good, things are obviously not perfect or even close to right at this point.  It's a good thing I have my other desktop based system which is still fine and stable under XP Pro.  At least I took the chance.  It might help someone down the road.  Who knows, I just may get this to work yet.  Perhaps I was a little over excited when I titled the thread too as was pointed out!  Embarrassed
    Dave
  • Mon, Nov 16 2009 6:29 AM In reply to
    • DylanReeve
    • Auckland, New Zealand
    • Posts 1,680
    • Points 20,605
    • Moderator: MCA Mac
    I've been runnning MC4 on my completely unqualified laptop in Windows 7 Pre-Release for a few months - it's been working fine for what I've been doing, but I haven't pushed it. I have no used any DNA or DX hardware and been sticking to basic cutting and effects. I did try an Audio Suite plugin and it didn't throw any errors, but it didn't seem to do anything either - but I didn't bother to investigate.
    Various systems - including HP Z440 and Z840 workstations Media Composer 2018 [view my complete system specs]
    Dylan Reeve - Edit Geek // Online/Offline Editor // Post Production Supervisor
  • Tue, Nov 24 2009 10:38 AM In reply to
    Hi, I'm runnig MC 4.03 on Windows7. Most of it works, no problem.
    The only thing I can't get right is my keyboard settings. Even if I edit them, some functions just won't work.
    Like the lift/overwrite key, Quick transition and more.
    Does anyone have/had the same problem?
    Maks
    MB: Asus P5WDG2-WS Pro, S775, i975X, 4x DDR2, ATX Intel Core 2 Duo E 6600 2.40 GHz, S775, 4 MB XFX Ge Force 7600 GT XXX 266 Mb 2 mb Kingston DDR2 PC2... [view my complete system specs]
    Maks
  • Tue, Nov 24 2009 10:44 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,971
    • Points 70,590
    This shouldn't be Windows 7 related: is Your keyboard configured for US english in the Windows control panel? With a localized (non US) keyboard function keys do not match. See this THREAD for more info. hth
    Symphony 24.12, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro T400 [view my complete system specs]
    peace luca
