Latest post Sat, Apr 3 2010 6:08 PM by Yadda. 11 replies.
Page 1 of 1 (12 items)
  • Thu, Sep 24 2009 8:41 AM
    • Peter Lund
    • Joined on Mon, Sep 22 2008
    • Hamburg
    • Posts 146
    • Points 1,755
    Select Clips in the Bin
    Hi ,
    when i whant to select several clips on a windows system i just select one clip an then i press shift and
    i select the top clip i what to select. So i get a selection of 10 clips.
    On the mac version of composer i need to lasso the clips, but when the bin is very full it is diffiicult to
    select the right clips.
    Is there any shortcut to select the clips like i do this on the windows system ?
    And why is that like this? If i swith to the finder it´s easy , i can select several clips with "shift" pushed down????
    It would make me smile to find a solution to the problem....
    i tested every shortcut from "alt" shift" to "ctlr shift" but i can´t find anything....
    And if not: is it possible to discuss this please in the betaforum?
    thanx
    Peter
    Hamburg, Sunny
    ___________________________________________________________________________________________________________________ Avid MC 7.0.4 /// MacBooks pro early... [view my complete system specs]
  • Thu, Sep 24 2009 9:23 AM In reply to
    Re: Select Clips in the Bin
    Why would you like to see it discussed in the Betaforum? That's for betatesting, not for new features. There's the feature request forum for that.
    And I think that what you describe is MacOS behaviour.
    Media Composer Symphony | PT Ultimate | Win11 HPZ | OSX MBP [view my complete system specs]
  • Thu, Sep 24 2009 9:59 AM In reply to
    • janusz
    • Paris
    • Posts 396
    • Points 4,710
    Job, it isn't exactly MacOS behaviour, although this has always been like this on Mac Avid systems as far as I can remember.
    Comparison:
    Finder:  To select a range: click on first, Shift-click on last; individual selection/deselection, cmd+click
    Avid (on mac):    To select a range; lasso; individual selection - shift click
    Cmd-click gives info on clip;  Shift-lasso inverts the selection on the lassoed clips (or adds to the selection if nothing is selected)
    There is no other way (to my knowledge) than lassoing to select a range of clips on the mac.  The Ctrl and Alt keys have no functionality when selecting (the Alt key changes the way clips open however).  So this is indeed a feature request.
    I agree with the original poster that this is incoherent behaviour, and an easy to implement feature request I would imagine.
    Janusz
    MC 2018.12 / OS 10.12.6 + others elsewhere [view my complete system specs]
  • Thu, Sep 24 2009 10:55 AM In reply to
    • siencs
    • Joined on Wed, Oct 17 2007
    • Aberystwyth, Wales
    • Posts 441
    • Points 5,210
      Avid Certified User
    Job ter Burg:
    Not true. At the finder (desktop) level, mac os functions the same as windows with regards to the shift key, but uses the command (apple) key instead of the control key to select multiple non-consecutive items from a list. I've never understood why avid on macs works the way it does in regards to this.
    It's also a myth that macs don't have right-click functionality too! (works via control-click if you only have a one button mouse)
    e2a sorry, loaded the tab when i arrived at work nd forgot to refresh before replying. Didn't mean to reiterate janusz's perfectly accurate reply.
    MC Symphony 8.8.5 on MacPro 3GHz 8-Core Xeon 12GB RAM, OS 10.12.6, Blackmagic Ultrastudio 4K MC Symphony 8.8.1 on iMac [view my complete system specs]
  • Thu, Sep 24 2009 12:48 PM In reply to
    I stand corrected.
  • Thu, Sep 24 2009 4:57 PM In reply to
    siencs:
    Because it used to be that MacOS (pre-OSX and possibly pre-OS9) operated the way that Avid does now.  So, Avid used that same method when writing the original code.
  • Thu, Sep 24 2009 9:33 PM In reply to
    • siencs
    • Posts 441
    • Points 5,210
      Avid Certified User
    Ah okay. must have been pre OS9. I don't remember the behaviour on my System 7 LC.
  • Thu, Sep 24 2009 11:22 PM In reply to
    • Evan Schiff
    • Los Angeles
    • Posts 121
    • Points 1,475
    To get back a bit to the OP's problem, there is a nice little space between the clip icon and the first column (generally the Name) that works great for lassoing. You might find it easier to lasso selected ranges of clips if you only try to lasso from that area of blank space in the bin.
  • Thu, Sep 24 2009 11:31 PM In reply to
    • Peter Lund
    • Hamburg
    • Posts 146
    • Points 1,755
    Hi ,
    it´s very interresting to see, that many editors are having the same problem, isn´t it?
    Thanx to everyone for the help.
    Where can i post requests ?
    Peter
    Hamburg , dark and clowdy
  • Mon, Oct 19 2009 11:52 AM In reply to
    • Pol
    • Belgium
    • Posts 283
    • Points 3,785
    I use the following. I select one clip, press shift and arrow down. The selector will go down and select one line after another. Not the same but the best you'll get on mac I'm afraid.
  • Mon, Oct 19 2009 3:17 PM In reply to
    Pol:
    I'm not so sure that's the "best" method.  SHIFT+lasso works very well (and fast)
  • Sat, Apr 3 2010 6:08 PM In reply to
    • Yadda
    • Norway
    • Posts 19
    • Points 235
    Can someone please move this to the Avid Product Feature Requests forum, if it's not already there?
    Mac Pro (OS X 10.6.2): Avid Media Composer 4.0.5 - Two 2.26GHz Quad-Core Intel Xeon, 6 GB memory, NVIDIA GeForce GT 120 512MB --- MacBook Pro (OS X 10... [view my complete system specs]
