I can't find any HDV deck template allowing me to capture HDV footage from a Sony HVR-Z5 camera connected via Firewire to a PC Avid MC 3.0.5.
Remote control works, but no video input.
Would appreciate any help.
Thanks in advance,
JDf
try other sony HDV cameras like HC-1 or Z1... sasha
Have you checked this?
Desktop
Asus Ζ690 TUF Gaming WiFi D4|i5 12600K|Corsair 128G DDR4|Asus 3060 12GB|Samsung 980 500GB(OS)|2X1TB Samsung 980 RAID 0|W11 Pro
Laptop
MSI Katana GF76 11UE (i7 11800H|Nvidia 3060|Crucial 64G DDR4)|W11 Pro
NLE
DR Studio 19.1.3|MC 2024.12
VDIM
Thanks.
I think my problem is somewhere else...
Now I'm on a Mac system, but it's the same as the PC. Most of my HVR templates are marked PAL in the end (as you can see in the screenshot) namely the HVR-Z1, which would be the "nearest" to HVR-Z5...
Project format is 1080i/50, Raster Type HDV.
Regards,
J. Difool:Most of my HVR templates are marked PAL
No, all your decks are marked as PAL (or "P" [=PAL] or "e"/"E" which is, at least for Panasonic and Sony, also often used for their PAL-versions of cams and decks.).
Maybe a silly question: assuming you are in NTSC-land and have SD(!) footage, have you started a NTSC-project in the first place?
If you have HDV-footage, as the title of this thread implies, have you tried the HVR-Z1 PAL setting? In the world of HD the differences between NTSC and PAL have nearly vanished: same colors, same count of vertical lines. Only the framerates still differ in some cases, I would give it a try, maybe it works.
Regards, g_f
