Latest post Wed, May 12 2010 5:55 PM by Job ter Burg. 10 replies.
Page 1 of 1 (11 items)
  • Wed, Apr 1 2009 2:15 AM
    Audio monitoring issues, Audio Tool only two tracks
    Very simple issue: I can't hear the audio on tracks 3 & 4.  Only audio that is being output to the speakers is on tracks 1 & 2.  I've looked at the Audio Tool, mix tool, etc.  Can't figure out what I haven't done to be able to hear the audio.  There's audio there, I can see the waveforms.  If I move it up to tracks one and two, I can hear it.  WHen I open the audio tool, it's only registering two tracks (channels).  A limitation of my software based system?
    I'm running the new 3.5 MCSoft.  On a MacPro (intel) 2.66.
    Just installed it two days ago.  Something simple I'm overlooking, but I've been through all the audio settings and have been unable to remind myself what I'm forgetting.
    Any help?
    How hard is that?
  • Wed, Apr 1 2009 3:25 AM In reply to
    Re: Audio monitoring issues, Audio Tool only two tracks
    Are 3 & 4 muted? or are 1 & 2 solo'd?
  • Wed, Apr 1 2009 2:18 PM In reply to
    • siencs
    • Joined on Wed, Oct 17 2007
    • Aberystwyth, Wales
    • Posts 441
    • Points 5,210
      Avid Certified User
    audio tool>PH (peak hold) button>output settings -  set to mono or stereo, not direct out.
    MC Symphony 8.8.5 on MacPro 3GHz 8-Core Xeon 12GB RAM, OS 10.12.6, Blackmagic Ultrastudio 4K MC Symphony 8.8.1 on iMac [view my complete system specs]
  • Fri, Apr 17 2009 10:49 AM In reply to
    • ritalee
    • Joined on Fri, Apr 17 2009
    • Spain
    • Posts 2
    • Points 20
    hi
    we are having the same issue, we are working on a macpro intel with upgraded 3.5.1 software only.
    This is only happening with xdcam ex (1080/50i) clips imported through Ama Link.
    if we edit an audio file in other format or a transcoded dnx120 clip there's no problem in tracks A3 A4 A5 A6... but xdcam ex is not playing audio, even vu-meter doesnt peak
    we can see the sample plot in A3 A4... but if we make an audio mixdown, the resulting clip doesn't show the sample plot
    no muted nor solo nor anything related...
    really annoying problem, we cannot overlap two audios... and transcoding is not a viable solution...
    aphollywood did find any solution?  what format are you working at?
    Macpro Intel 2 x 2,66 GHz Leopard 10.5.6 - Quicktime 7.5.5 MediaComposer 3.5.1 Software Only [view my complete system specs]
  • Fri, Apr 24 2009 12:14 PM In reply to
    • ritalee
    • Spain
    • Posts 2
    • Points 20
    bump
  • Tue, Sep 29 2009 2:58 AM In reply to
    Hi there,
    I'm having this exact same problem with the XDCAM EX files linked through AMA. I too can see the waveform on A3 & A4 but can only monitor A1 & A2.
    I notice these posts are from a few months ago though. Has anyone found a solution?
    Any help much appreciated!
  • Tue, May 11 2010 11:21 AM In reply to
    • pebe
    • Joined on Mon, Mar 22 2010
    • Warsaw, Poland
    • Posts 34
    • Points 465
    I have a relating issue, audio tool only shows 2 channels, how can I set it to show 4 or more channels?
    Avid Media Composer 4.0.2 | AMD Athlon 64 X2 4400+ 2,2 GHz | Foxconn A690GM2MA | 2GB A-data DDR2 | Palit GF 8600GT 256MB DD3 Sonic+ | HDD Samsung 1TB ... [view my complete system specs]
  • Tue, May 11 2010 1:10 PM In reply to
    Change your Audio Project Output settings to Direct Out. Depending on how you set it up, you then get 4 or 8 channels.
  • Tue, May 11 2010 1:15 PM In reply to
    • pebe
    • Warsaw, Poland
    • Posts 34
    • Points 465
    I have only mono or stereo available, no direct out.
  • Wed, May 12 2010 6:40 AM In reply to
    Ah sorry, Direct Out is only available if you have some output device that has more audio channels. These output devices can be Mojo, Mojo SDI, Mojo DX or Nitris DX.
    Unfortunately, these meters do only show the actual output channels, not the timeline tracks.
  • Wed, May 12 2010 5:55 PM In reply to
    One thing: are you asking about seeing more than two channels in the Audio Tool (the audio meter I mean)?
    Cause this thread was about an AMA issue with XDCAM, that is not really related.
