Latest post Fri, Oct 2 2009 2:42 PM by mjolnarn. 59 replies.
Page 4 of 4 (60 items) < Previous 1 2 3 4
  • Tue, Sep 29 2009 7:32 AM In reply to
    Re: AVCHD editing
    am trying to transcode .mts files from my HDR-SR5 in Mainconcept avchd to dvcprohd converter. V1.1
    But I only get GREEN video?
    anyone had this issue? found a solution?
    thanks
    Social Media Manager at Avid
    Editor-in-Chief avidblogs.com
    Got a great story to tell for #TimelineTuesday?
    Want to share a Media Composer Tutorial on #TutorialThursday?
    Contact me!
    Twitter: @editorbelga
    Facebook: fb.com/editorbelga
  • Tue, Sep 29 2009 8:24 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    Re: AVCHD editing
    editorbelga:
    I am using the same version, are you seeing the green video during the encoding process or when importing it into MC?
    Tomas
  • Tue, Sep 29 2009 9:30 AM In reply to
    Re: AVCHD editing
    While encoding (in the preview monitor)
    and of course while importing in MC afterwards.
    thanks
    Contact me!
  • Tue, Sep 29 2009 10:09 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    Re: AVCHD editing
    editorbelga:
    thanks
    Ok, sorry to say, but there are no settings in the transcoder to change codecs, it might not be possible to use it for this kind of clips.
    Just to try and test another encoder, there are trial versions, maybe with waterstamps, from mainconcepts website.
    Tomas
  • Tue, Sep 29 2009 10:33 AM In reply to
    • monkeyberry
    • South Africa
    • Posts 647
    • Points 7,985
    Re: AVCHD editing
    nice sales pitch shirley..!!!!!
    i see all your recent posts are pushing this product.  now we know why you a member here :)
    System Specs Sufficient :) [view my complete system specs]
  • Tue, Sep 29 2009 10:41 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    Re: AVCHD editing
    monkeyberry:
    Yes, I have also noticed that, but as the converters from mainconcept has worked well I see no need to change brand, new apps are coming all the time, recommendations to use them should come from some experienced well known editors I think rather than from the sales department for the new app.
    Tomas
  • Tue, Sep 29 2009 1:29 PM In reply to
    • lalittle
    • USA
    • Posts 534
    • Points 7,365
    Re: AVCHD editing
    Does anyone know if Procoder 3 can do this conversion as well?  I don't have files to test here, but I did confirm that Procoder 3's "Quicktime plugin" conversion allows you to select DNxHD codecs for "quicktime movies."  I also know that Procoder specs state the ability to read AVCHD files.  The only question seems to be whether or not your specific "brand" of AVCHD files can be read correctly by Procoder since AVCHD does not appear to be a very "standardized" standard.
    Does anybody have any experience with Procoder for AVCHD-to-DNxHD comversions?  Sorenson always screws up playback of certain streaming files for me (including version 5), so I prefer Procoder (I always have to uninstall Squeeze to get streaming to work properly.)
    Larry
  • Tue, Sep 29 2009 1:49 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    Re: AVCHD editing
    I guess that one of the ups with using the encoder we just mentioned is the possibilities to use AMA for direct import, works very nice, Procoder might create a file if it works and in that case, with the correct settings, it might fast import, the AMA workflow is much faster and easier I think.
    Tomas
  • Wed, Sep 30 2009 1:40 PM In reply to
    • lalittle
    • USA
    • Posts 534
    • Points 7,365
    Re: AVCHD editing
    mjolnarn:
    Forgive me, but which post are you referring to when you say "using the encoder we just mentioned."?  I'm confused by what specific workflow you're advocating.  Aren't we talking about creating DNxHD files from AVCHD files?  If so, what difference does it make which encoder is used to do it as long as you end up with DNxHD files?
    Also, doesn't AMA only work with XDCAM, P2, or GFCAM files?  How does this relate to AVCHD to DNxHD conversion?
    Larry
  • Wed, Sep 30 2009 2:05 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    Re: AVCHD editing
    lalittle:
    mjolnarn:
    Larry
    Sorry, I was in two posts at the same time and mixed them, this was the thread I had in my mind, works very well with AVCHD clips, sorry if I got you confused, the man is getting old ...
    edited..  not so old, we have actually been discussing this workflow on this page, page 4, even in this thread
    Tomas
  • Fri, Oct 2 2009 2:02 PM In reply to
    • lalittle
    • USA
    • Posts 534
    • Points 7,365
    Re: AVCHD editing
    mjolnarn:
    Thanks.
    You mean using the Panasonic converter to convert the AVCHD to DVCPro HD?  If so, the problem with this is that it has slightly less horizontal resolution (1280x1080 or 960x720) than the AVCHD (1920x1080 or 1280x720.)
    Larry
  • Fri, Oct 2 2009 2:19 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    Re: AVCHD editing
    lalittle:
    mjolnarn:
    No, the mainconcept converter, please read the first posts on this page, page 4, again
    Tomas
  • Fri, Oct 2 2009 2:25 PM In reply to
    Re: AVCHD editing
    digitalhecht:
    VERY quickly and plays them quite smoothly for me. So I don't see the point of converting them to DNxHD files when the import times are about 5 times as long and the file sizes are 10-12x larger (than m2t files). They all look fine to me. Now, as thge increase in file size from MTS to m2t is moderate (not even 1.5x!), I am open to suggestions to tweaking the AME settings to get a bit more quality out of the encoded files, i.e. raise the minimum and/or maximum mbps, etc. Perhaps I am losing more than I realize? I'd be curious to see how others fare using these settings.
    Tawk amongst ya'selves. Discuss.
    The trick is to choose settings in TMPGEnc that will allow the file to "Fast Import" in Avid. That means choosing "Millions of Colors" instead of "Millions of Colors+" and setting Alpha to "None."
    (I always make sure the Media Creation settings for the MC project match the version of DNxHD I've transcoded to in TMPGEnc, but I'm not sure if this is a necessity.) I believe you also have to be sure that Avid's import settings are 601/709 levels for it to fast import.
    When you get the settings matching properly so you can fast import the files, the importation happens very quickly and there is no additional trascoding, e.g. quality loss happening.
    HTH.
  • Fri, Oct 2 2009 2:37 PM In reply to
    Re: AVCHD editing
    Wm Warne:
    I hope this post goes where I want it to go.  Two quick comments.  (1) Would it be possible to have a AVCHD forum or heading so that all of these wonderful posts could be organized in one place (there are a series of threads that are pertinent)?  (2) I agree that it is inevitable that MC will include AVCHD import.  When that happens (note to Avid), ...
    I strongly suggest going to the Chat with Avid fourm and posting a thread with these sentiments. ;)
  • Fri, Oct 2 2009 2:42 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    Re: AVCHD editing
    mjolnarn:
    lalittle:
    mjolnarn:
    If anyone can confirm that the base version of AVCHD to DVCPrOHD , version 1,1 , still is a free one, it was once upon a time, I can add it to my web and publish a link but no illegal things, we have to be sure that it is still free.
    Tomas
