Latest post Sun, Jun 8 2008 1:59 AM by hbrock. 2 replies.
  • Tue, Jun 3 2008 9:18 PM
    • CCMandy
    • Posts 9
    • Points 135
    Audio Tool
    Quick question that probably has an easy solution...
    How do you set your audio tool to show four bars instead of two? And vice versa?
    It has always baffled me how one day I will just have two bars bouncing, then the next day when I open the same project, four will be showing. Anyone know?
    Media Composer 6.5.3 / Mac OS X 10.7.4 / 2x2.66 GHz Quad-Core / 8 GB RAM / NVIDA GeForce GT 120 512 MB
    Filed under: , , , , ,
  • Tue, Jun 3 2008 9:57 PM In reply to
    Re: Audio Tool
     Perhaps your timeline setting was on firewire mode instead of edit mode. On MCA, this is also selectable under the special menu when selecting "device". When in firwire mode, the audio tool will revert to 2 channels.
  • Sun, Jun 8 2008 1:59 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,545
    • Points 64,610
      Moderator: MCA Mac
    Re: Audio Tool
    You need to set the project audio sample rate to 32k if you're doing a DV project if you want to have 4 channels of audio.  This will also necessitate converting any 48k audio clips to the new sample rate before outputting.
