Latest post Sun, May 4 2008 11:31 AM by Tentaor. 5 replies.
Page 1 of 1 (6 items)
  • Thu, May 1 2008 1:23 PM
    • Tentaor
    • Joined on Thu, Nov 15 2007
    • Posts 52
    • Points 595
    a method to convert a resize effect in a PIP effect?
     Hi everybody!
    Anybody knows a method to convert a resize effect in a PIP effect?
    If I´ve a picture with a resize effect (with crop and position values changed) and I sudenlly decide to use it with other image in a below track as background. Ther are any method to do it?
    Thanks!
    Sorry for my english. I´m spanish!
    Media Composer 2022.7 MAC STUDIO MAX 64GB MAC OS 12.3.1 Monterey /// IMAC 27 LATE 2013 32 GB RAM MAC OS Catalina 10.15.7 [view my complete system specs]
  • Thu, May 1 2008 1:51 PM In reply to
    • applebuckets
    • Pittsburgh, Pennsylvania
    • Posts 228
    • Points 2,920
    Re: a method to convert a resize effect in a PIP effect?
     You have to step in to the effect.  With a PIP or re-size effect applied to the clip, click on the step in button (an arrow pointing down located on the top left of your timeline by default). Once in, apply your effect, then step out using the up arrow. That's how you get effects not to affect all the tracks below.
    Good luck
    MCA 6.01 hp xw8600 Windows 7 16GB RAM Nvidia FX3700M Matrox MX02 hp xw8400 Windows 7 16GB RAM Nvidia FX3700 MacBook Pro 2.2Ghz, 4GB RAM... [view my complete system specs]
  • Fri, May 2 2008 12:02 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,446
    • Points 98,375
    I think the question really is "can I convert a Resize effect to a PIP?"  In that case stepping into the effect won't help.
    I'm not in front of my Avid now, but this might work.  If you can promote the Resize to 3D it will become a PIP.  Then all that you would have to do is disable the background color.  If this doesn't work then I'm not sure that you can.
  • Sat, May 3 2008 10:21 PM In reply to
    • Tentaor
    • Posts 52
    • Points 595
     It was very simple. Thanks a lot jwrl. I didn´t thinked this.
  • Sun, May 4 2008 1:23 AM In reply to
    • jwrl
    • Posts 8,446
    • Points 98,375
    Glad to help.  Personally I've never understood why Avid has two separate tools that essentially do variants of the same thing.
  • Sun, May 4 2008 11:31 AM In reply to
    • Tentaor
    • Posts 52
    • Points 595
     Cuanto más aprendo Avid más lo odio. :)
    Trying to traslate: How much I learn Avid I hate it a little more. :)
    Thanks a lot.
    If I will had a MAC I´ll tried Final Cut and compare but how I haven´t it Isay ¡Viva Vegas Video!
