Latest post Mon, Mar 24 2008 7:44 PM by alex1. 4 replies.
  • Mon, Mar 24 2008 12:36 PM
    • alex1
    • Joined on Mon, Mar 24 2008
    • Posts 3
    • Points 35
    reformat from tk
    Hi guys. Am fairly new to Avid xpress pro so forgive the newbie question Smile I am editing a short which has been tk to full height 16:9 anamorphic. I have set my composite window to 16:9 and am obviously working on a widescreen monitor. However, i can't seem to get the footage to resize via the reformat option in the effects palette. The reformat effect simply squashes my image. The footage is S16mm tk to miniDVCAM.
    This is probably a simple process but I can't seem to get my head around it.
    Also am I wrong to build the project as a 50i project seen as the film is clearly 25fps??
    many thanks
    Alex
    Intel Pentium CPU 3.00GhHz, 1.5 GB 100GB, 1TB exte [view my complete system specs]
  • Mon, Mar 24 2008 12:51 PM In reply to
    Re: reformat from tk
    if your footage is anamorphic and you switch to 16:9 monitor you don't need to reformat. Anamorphic in is anamorphic out. I always work with 50i unless a 25p master or a neg cut needs to be done. 50i also allows an online on almost all Avids (my onliner is an MC1000XL). P projects have less resolutions available. Someone else may now a reason why 25p is preferable but I don't.
    Edit 1: MC 8.10 + Symphony + PhraseFind • MacPro 6x3.5GHz/64GB OS10.10.5 • Artist Mix & Color • Aja Io 4K • Edit 2: MC 8.10 • MacPro 2x2.66GHz/48GB... [view my complete system specs]
    Rodney Sewell BFS
  • Mon, Mar 24 2008 2:41 PM In reply to
    25p also allows for 50i conform, since 25p sequences can be opened in 25i projects (even on Meridien).
    Not anymore. 3:1p, 2:1p and 1:1p are all available now, not just on Symphony (as was the case in the Meridien days).
    Any wipes and DVE-type moves will be animated in 25p rather than 50i. Plus you get the ability to do 24p outputs for film dubbings.
  • Mon, Mar 24 2008 7:36 PM In reply to
    Hi Job, thanks for that info!
    Rodney Sewell BFS
  • Mon, Mar 24 2008 7:44 PM In reply to
    • alex1
    • Posts 3
    • Points 35
    thanks guys, that helps.
