Latest post Wed, Mar 19 2008 10:11 PM by Freddy. 10 replies.
Page 1 of 1 (11 items)
  • Mon, Mar 17 2008 5:48 PM
    • Ivo
    • Joined on Fri, Oct 21 2005
    • Germany
    • Posts 522
    • Points 7,040
    How to import footage from the Sony PMW-EX1 camera?
    I tried to export the footage with the clip browser software 1.01 to MXF files. But after import in avid 2.7.7 I got pictures with green lines. Any idea how to do it?
    Avid Media Composer 2018.9 MacBook Pro [view my complete system specs]
  • Mon, Mar 17 2008 5:52 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,737
    • Points 227,790
      Moderator: MCA Mac
    Re: How to import footage from the Sony PMW-EX1 camera?
    You will get that result when attempting to use the 35mb resolution from that camera (not supported in Avid) Is that what you are doing?
  • Mon, Mar 17 2008 5:54 PM In reply to
    • Ivo
    • Germany
    • Posts 522
    • Points 7,040
    Yes that is right.
  • Mon, Mar 17 2008 6:06 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,737
    • Points 227,790
      Moderator: MCA Mac
    Can't do that. This post might help you with a workaround though
    http://community.avid.com/forums/t/55459.aspx
  • Mon, Mar 17 2008 6:44 PM In reply to
    • Ivo
    • Germany
    • Posts 522
    • Points 7,040
    Isn't this just for mac? I can just export to MXF, not to mov.
  • Mon, Mar 17 2008 6:50 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,737
    • Points 227,790
      Moderator: MCA Mac
    The workaround you mean? Avid's non-support for 35mb is across the board.
    Probably.
    Might be an option if you have a mac around though.
  • Tue, Mar 18 2008 12:36 AM In reply to
    • Freddy
    • Joined on Sun, Nov 5 2006
    • Sweden
    • Posts 256
    • Points 3,110
    For now, you can use ffmpeg to convert from XDCAM EX 35 -> DNxHD
    http://www.bolanski.com/ex/
    p.s. ffmpeg can be used for other formats* -> DNxHD
    *..like divx and other funky formats.
    http://www.freddylinks.com <-- Find EVERYTHING Avid and Tutorials there. Probably the most comprehensive Avid only webpage with over 2000+ Links to Avid Video Tutorials and Avid Information for Media Composer, NewsCutter, Symphony, Interplay, ISIS, Unity MediaNetwork, ProTools, Avid Artist Series. Completely free of fees, registrations, and ads.
  • Tue, Mar 18 2008 9:07 AM In reply to
    • Ivo
    • Germany
    • Posts 522
    • Points 7,040
    It works fine but no 185X or uncompressed Resolution.
  • Tue, Mar 18 2008 9:18 PM In reply to
    • Freddy
    • Sweden
    • Posts 256
    • Points 3,110
    Why whould you convert to DNxHD 185x? The source material is only 8 bit..
    XDCAM EX 8bit -> DNxHD 8bit = Yes
  • Wed, Mar 19 2008 7:48 AM In reply to
    • Ivo
    • Germany
    • Posts 522
    • Points 7,040
    Isn't it better for CC? Also 185 isn't possible. Just 175. I never heard of that resolution.
  • Wed, Mar 19 2008 10:11 PM In reply to
    • Freddy
    • Sweden
    • Posts 256
    • Points 3,110
    Here is a very Geeky and cumbersome way, but it works.
    If you use the dos command from that link insted, you can actually convert the files.
    Unpack the zip file you got linked on the bolanski page.
    Use Sony Clip-Browser, Rightclick export as MXF.
    Copy the XDCAM EX 36 file to the same direcotory
    Click Start -> Run -> (in the field type "CMD" without the quotes, klick OK)
    Here's a pretty good video of DOS basics (I didn't create it)
    http://www.youtube.com/watch?v=OHeJRYgdyik
    Then go to the directory where you unpacked the XDCAM_EX_to_Avid_0.5.zip
    Type this command, modify the underlined words with your filenames for the MXF Files.
    ffmpeg -y -i inputfile.mxf -vcodec dnxhd -b 185Mb -an outputfile.mov && ffmpeg -y -i inputfile.mxf -vn -acodec pcm_s16le outputfile.wav
    This will convert the inputfile.mxf to outputfile.mov (DNxHD 185) and outputfile.wav (Audio)
    This workaround is very temporary as support for EX1 36 media will be supported very shortly. By the way you can use the same command prompt for converting
    loads of other formats. mpeg, divx, xvid, wmv and more. (I have only tested a few).
    Happy Hacking.. Surprise
