Latest post Sat, Jun 18 2022 9:20 AM by AndrewAction. 3 replies.
  • Thu, Oct 13 2005 11:00 PM
    • wmcole
    • Posts 599
    • Points 8,150
    Keyboars Assignment Feature Request
    Currently, when editing keyboard short-cuts (Settings->Kyboard) if you press the Shift key, the display changes to show the short-cuts assigned to shifted key presses.  This dialog needs to be updated so that the same functionality applies to the ALT and CTRL keys.
    If I recall correctly from my old days in software engineering when our 'input console' was a teletype machine, the ALT and CTRL alone may not put out a signal that can be picked up like the Shift key can be.  In that case, the ALT and CTRL keys should be selectable on the keyboard map (click, double-click, alt-click....), provide feedback that they are selected, (i.e. appear depressed or otherwise highlighted) then allow the usual short-cut mapping operations to the ALT or CTRL modified key of choice.
    wmc
    HP z840 dual 8-core; PCI slot 3, Creative SB X-Fi audio card; 32 GB Ram; 4 x 1 TB RAID 5 internal SATA Western Digital Caviar Green Media drives (appears... [view my complete system specs]
    wmc
  • Fri, Jun 17 2022 5:10 PM In reply to
    • Ssnygg
    • Joined on Tue, Apr 11 2006
    • Allentown PA
    • Posts 405
    • Points 4,845
    Re: Keyboars Assignment Feature Request
    Agreed!! We definitley need to be able to assignm more keyboard shortcuts by allowing Alt, CTRL and any combination of alt, ctrl, shift in order to have not just two keyboards worth of shortcuts but many.  I have wanted this for MANY years.
    I have several systems. 1-Media Composer ver 5 1-Media Composer 2021.6 on Win 10 1-mac Express 2.2 AB/VB Targa set up The computers I use include: 1-Intel... [view my complete system specs]
  • Sat, Jun 18 2022 1:55 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,449
    • Points 98,420
    Lightworks does exactly that, and also allows other arbitrary key combinations.  You can assign V1 to select video track 1 for example.  That's not the best example I guess, but you take my point.  It can be incredibly useful.
  • Sat, Jun 18 2022 9:20 AM In reply to
    wmcole:
    Have you looked in the MC Help menu with a project open? It looks like there are quite few Alt and Ctrl options there under shortcut options using CTRl key and Alt Keys. I only recently came across these whilst looking for more options to use in my Stream Deck MC Profile.
