Latest post Tue, Dec 5 2006 7:04 PM by RobertH. 5 replies.
Page 1 of 1 (6 items)
  • Sun, Dec 3 2006 7:36 PM
    • Tugger
    • Champaign Illinois USA
    • Posts 676
    • Points 8,770
    5.6.3 possible memory leak is back
    Hi Guys
    Just an fyi for the (admittedly) few who suffered this on the 5.5x versions. Opened a small project (single bin) captured 20 minutes of DV, a few titles and and couple graphics and the memory use shoots up to 70% (with accompanying warning) No such problem in 4.x or early 5.x, only cropped up in 5.5 and resolved in 5.6.2. Rolled back to 5.6.2, same project sitting at 3% memory useage.
    I never had the j-k-l problem, or any of the other specifics repaired in 5.6.3, so no biggy, just fyi for the code writers to take a look at what might have changed between .2 and .3
    thanks
    MediaComposer 2018.X on HP8770 Windows10pro / MediaComposer 5.5 on HP8740.eSATA external media drives. Samsung 24" computer monitors when in office... [view my complete system specs]
  • Mon, Dec 4 2006 5:35 AM In reply to
    • RobertH
    • Pasadena CA
    • Posts 84
    • Points 1,050
    Re: 5.6.3 possible memory leak is back
    Tugger,
    That's interesting. I did have the JKL issue. But nothing else. I just batch digged in 4 hours of beta SP, went in and did some quick effects, 3D etc. No memory problems. no glitches, system did not even seem to notice.(I;m on 5.6.3)  Huh, go figure eh? I need to dig in some DV soon, I will keep an eye on that, see if there is any common thread there. Thanks
    Asus A8N-SLI Deluxe Motherboard - - 2 x PCI Express x16 slot, SLI mode : x8 , x8, Default(Single VGA) mode : x16, x1, - 2 x PCI Express x1, - 3... [view my complete system specs]
    RobertH Life is in you today, and you make your own tomorrow!
  • Mon, Dec 4 2006 10:11 PM In reply to
    • CMG11
    • Posts 19
    • Points 245
    I have a similar memory problem,   but had it on 5.6.2 and now on 5.6.3 -- never had this sort of problem on 4.6
    I have a dell 340, 3.1 ghz, 1gb of Ram and a parhelia 128mb with multip[le drives.
    When I open one bin the memory usage shoots up to 50-70%.  Then I try to open a second bin and it goes to 95-100% and crashes.
    Is there a problem with the software? What else could it be.
    CMG11
  • Mon, Dec 4 2006 10:40 PM In reply to
    • Freddy
    • Joined on Sun, Nov 5 2006
    • Sweden
    • Posts 256
    • Points 3,110
    Upgrading to 2GB will have a huge difference in performance.
    I think they have increased the buffer size since 4.6.
    ...just my 2cents
    http://www.freddylinks.com <-- Find EVERYTHING Avid and Tutorials there. Probably the most comprehensive Avid only webpage with over 2000+ Links to Avid Video Tutorials and Avid Information for Media Composer, NewsCutter, Symphony, Interplay, ISIS, Unity MediaNetwork, ProTools, Avid Artist Series. Completely free of fees, registrations, and ads.
  • Tue, Dec 5 2006 2:14 AM In reply to
    • scocklin
    • Maryland
    • Posts 675
    • Points 8,170
    I had the same problem tonight with 5.6.3 and 2GB of memory. After doing some titles and lowerthird matts I tried to render and got the Out of Memory warning. Had to shut down and start up again. Is this a problem that will be fixed with a later ver. or should I buy more memory?
    HP-Z6-G4 Workstation, 1-Xeon 4216 16 core processor, 64GB 2933MHz DDR4 ECC Memory, P4000 GPU, 512GB NVMe 1TB NVMe, Thunderbolt 3 controller,HP Base Front... [view my complete system specs]
  • Tue, Dec 5 2006 7:04 PM In reply to
    • RobertH
    • Pasadena CA
    • Posts 84
    • Points 1,050
    There is a known bug with XP Pro regarding how it handles dual processors and dual core processors. It has to do with timing -- this can be a situation -- you may want to check out these articles:
    Microsoft Article:
    http://support.microsoft.com/?id=896256
    Dual Core Article:
    http://support.microsoft.com/kb/909944/
    There is a different handling for Dual Core and Dual processors. So read carefully. It would be good to rule out any issues. When I did the fix, it handles some issues I was having after going to 5.5.2, I am now on 5.6.3 and all is working fine so far.
    Hope this helps.
