Latest post Tue, Mar 25 2025 6:20 PM by Marianna. 4 replies.
  • Thu, Mar 20 2025 12:41 AM
    • IanD
    • Posts 25
    • Points 340
    No buttons show up in Effect Mode
    Hello everyone About half an hour ago I was working on editing a project and accidentally pressed some buttons on my keyboard; now, whenever I go from Source/Record mode into Effect mode on the timeline, nothing changes and none of the usual buttons show up under the monitor; as an example, there's no pink triangle button to add a keyframe. I have no idea how this happened, and I don't have a clue how to fix it. Restarting Avid hasn't worked, and all I haven't had any luck with an internet search. Has anyone had this problem, and if so, how did you fix it? Thanks.
  • Thu, Mar 20 2025 2:09 AM In reply to
    Re: No buttons show up in Effect Mode
    ...check your keyboard settings....create a new default KB and use that and see if it helps...
    I9-NVidia3060-160ram-WIN11PRO-MC24.12-NewBlueFX-Photoshop-Shutter Encoder-Boris Continuum 12.5-VLC Player-Resolve 19.1.4-I5 iMac-64RAM [view my complete system specs]
  • Thu, Mar 20 2025 6:38 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 1,144
    • Points 14,525
    also...try resetting your workspace back to default or even create a new user, which should also reset evrything back to their default values.
    HP Z800, HP G9 Fury, SonnetFusion RAID, Mojo DX, Decklink 4K, Ultrastudio 3G/4K, Symphony 2018 & 2023, Boland BVB25 OLED, JVC DTV1910 HD CRT, Eizo... [view my complete system specs]
  • Tue, Mar 25 2025 5:46 PM In reply to
    • IanD
    • Posts 25
    • Points 340
    I'm afraid neither of the suggested fixes worked, but I did find a solution: I entered effects mode on the timeline, bought up the command pallet (Tools -> Command Palette), and manually clicked and dragged the keyframe button onto the list of commands under the monitor. I hope this helps anyone else who has this same problem.
  • Tue, Mar 25 2025 6:20 PM In reply to
    • Posts 12,096
    • Points 261,795
    • ! Avid Employee
      !Avid Customer Advocate
      Avid Beta Moderators
      ForumsAdministrator
      Moderator: Edit on Demand
      Moderator: SSAI PHAI
    IanD:
    Thanks for this Ian......
    Glad that you figured it out but Im going to check to see why this happened and if I find out, I'll ping you offline.
    Sr. Director | Customer Experience and Community [view my complete system specs]
