Latest post Sat, Mar 8 2025 11:53 AM by Michael from cologne. 24 replies.
Page 1 of 2 (25 items) 1 2 Next >
  • Wed, Feb 12 2025 9:23 AM
    Do I need a new workstation? Or just a new graphics card?
    Hi all, I need your opinion!
    I have got an 8 years old HPZ840 with the following specs:
    Intel Xeon E5-2640v3 2.6 1866 8C 1stCPU
    Intel Xeon E5-2640v3 2.6 1866 8C 2ndCPU
    32GB DDR4-2133 (8x4GB) 2CPU Registered RAM
    NVIDIA Quadro M4000 8GB 4xDP 1st
    512GB SATA 1st Solid State Drive
    At the moment I am still on WIN10. I never had issues with the system and it still works fine for most of my work.
    Would an upgrade to a new workstation (budget around 5K) be a game changer in performance?
    The only thing I really miss is a bigger Monitor with WUHD-5K2K resolution. Unfortualtely the Quadro M4000 does not support above 4k. Would it make sense to just swap the graphics card to a newer one wich supports 5k? Is there a cheap one that works fine with Avid/Premiere?
    Michael
    MC 2022.12.06, WIN 10 x64, HP z840, dual E5-2640v3 2.6Ghz, 8x4GB RAM, Nvidia Quadro M4000, MXO2 LE, Artist Mix [view my complete system specs]
  • Wed, Feb 12 2025 1:53 PM In reply to
    Re: Do I need a new workstation? Or just a new graphics card?
    I think you could easily get more value out of that machine by simply upping the RAM to 128GB or so and swapping out the GFX card for something newer.
    Try and get a PCI SSD instead of a SATA one and that should also give you a nice speed boost. In times like these, wring every penny out of your current kit. Those machines were always solid performers.
    Andi
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 64GB RAM Win 10 Pro MC Ultimate 2022.10 MacbookPro 15 2019 6 core 2.6GHz i9 32GB... [view my complete system specs]
  • Wed, Feb 12 2025 6:21 PM In reply to
    z840 can take nVME in stead of HDD or SSD -- and NVME makes a difference. And yes, you'd be better off with more RAM on that machine.
    Media Composer Symphony | PT Ultimate | Win11 HPZ | OSX MBP [view my complete system specs]
  • Wed, Feb 12 2025 9:21 PM In reply to
    Thanks, that sounds good and would spare me a lot of money...
    Could you recommend a graphics card that does the job while supporting higher resolutions than the quadro m4000?
    Michael
  • Wed, Feb 12 2025 10:01 PM In reply to
    The GFX card would not be the first thing on my list to replace. That m4000 can drive 4 4K monitors at 60Hz. So I reckon it can drive more than just one 5K monitors (although they may require a dual-displayport connection).
  • Wed, Feb 12 2025 10:08 PM In reply to
    That might be convoluted, though -- replying to myself here.
    Avid also specify a p4000 which does run 4x 5k monitors.
    https://resources.avid.com/supportfiles/config_guides/AVID%20HP%20Z840%20Config%20Guide%20-%20Rev%20E.pdf
  • Thu, Feb 13 2025 12:12 AM In reply to
    ...dont expect a real speed boost going to NVME over your solid state SATA as your WIN drive.....yes, its faster but not enough to make a real world difference that is noticeable to the end user....great as can be for storage for media you want to edit with...blazing for that....
    ....RAM for sure....interesting that is all it really takes to be up to date ...just RAM....and inexpensive NVME storage....
    I9-NVidia3060-160ram-WIN11PRO-MC24.12-NewBlueFX-Photoshop-Shutter Encoder-Boris Continuum 12.5-VLC Player-Resolve 19.1.4-I5 iMac-64RAM [view my complete system specs]
  • Thu, Feb 13 2025 12:31 AM In reply to
    Hello!
    Michael from cologne:
    It's virtually impossible to answer this question without a better understanding of which type of material you edit. Do you use GPU-intensive tasks like PhraseFind indexing? Do you do online editing or just offline (proxy) editing?
    If you're looking to improve PhraseFind indexing performance, upgrading your GPU would make sense. If you're working with big sequences and find yourself running low on RAM, I would upgrade that. If you'd like faster render/transcode times, get a new system with a better, more up-to-date CPU.
    There is a certain level of overhead managing two CPUs rather than one. And as long as you have over six cores, core speed is what really becomes important.
    Another consideration is power draw... Quite sure a Z840 is powerhungry and loud
    Freelance Film Editor | Technical Expert @ Avid
    [email protected]
    My Equipment & System Specs
  • Thu, Feb 13 2025 4:15 AM In reply to
    .....when i finally get that cushy university job teaching editing......
    ....on day one we will teach the proxy workflow.....
    ....or even to high school kids on a two day course....
    ...it needs to be that basic.....
    (and just about anything can handle it these days....)
  • Thu, Feb 13 2025 9:45 AM In reply to
    Hi all!
    Thanks for your opinions, fortunately theres nobody really encouraging me to buy a new system :-).
    - So I'l upgrade RAM to 128GB
    - Get an 2TB NVMe drive (I need more space anyway)
    - Look for a reasonable but good value graphics card
    regarding NVMe:
    Is the process of a clean system intall on an NVMe the same as on a SATA?
    regarding graphics:
    Basically I'am mostly editing in FHD with Avid or Premiere, little effects, sometimes I use After Effects but for "easy stuff".
    Would a nvidia T1000 do the job? Other recommandations? I would love to stay under 500€/$ for the GPU, max. 1000€/$ but only if it really needs to...
    Michael
  • Fri, Feb 14 2025 11:15 AM In reply to
    NVME and SATA the same install.....are you sure your PC will support an NVME Boot drive?  Does the board have a NVME slot or are you using an add in card?
  • Fri, Feb 14 2025 11:58 AM In reply to
    That’s an excellent question -- yes the nvme drive requires a pci slot in the z840. It will gladly boot from it but I can't remember if it requires a change in the boot order in the bios. HP offered the Turbo Z drive option, which was a pcie card with twin nvme's. That's what mine came with. Currently rocking a 2TB nvme.
  • Fri, Feb 14 2025 12:45 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 1,144
    • Points 14,525
    There's a thread on the HP Community site which goes into NVME drives on the 840
    see here...
    https://h30434.www3.hp.com/t5/Business-PCs-Workstations-and-Point-of-Sale-Systems/Z840-PCiE-Bifurcation-for-M-2-NVMe/td-p/8717269
    HP Z800, HP G9 Fury, SonnetFusion RAID, Mojo DX, Decklink 4K, Ultrastudio 3G/4K, Symphony 2018 & 2023, Boland BVB25 OLED, JVC DTV1910 HD CRT, Eizo... [view my complete system specs]
    A quick google will turn up plenty of Youtube videos on how to install an nvme drive as boot on an z840.
    Andi
  • Fri, Feb 14 2025 7:36 PM In reply to
    ...maybe just get a bigger solid state SATA drive for the WIN boot and be done with it?  It won't make any real difference...
    ....formatting and reinstalling a fresh WIN would be just as effective as any NVME swap....and then, you don't spend any money on your boot drive but could spend it on screaming fast NVME storage for media....
