No matter what I try, I can't export any sequence. I've changed export settings. I've changed how I mport the media. I always get the same error message:
Assertion failed: FALSE
File: /Users/releng/Builds/workspace/MC/Release_Installer_Git/ Mac_Build/ppg/MediaComposer/PublishDialog/src/ PublishSettingsQT.cpp, Line: 302
Does anyone have an idea what's going on? i am using Avid First on a Macbook Pro running Sonoma 14.2.1
right click on the record monitor and use that export function
PublishSettingsQT.cpp tells me it's a UI drawing issue.
You using export presets?
Issue persist with reinstall/new user profile?
Freelance Film Editor | Technical Expert @ Avid
[email protected]
My Equipment & System Specs
Tried that -- still crashes :(
I've had the same issue, even with a re-install. I don't know why but I don't see under settings/user a place to change my user profile. In fact, the overall amount of options I have is limited: Audio ducking, Bin, Clipinfo Settings, Controller Settings, Full Screen PB, Import, Interface, Keyboard, Link, Sequence Template, Titler+ and Tool Palette. Nothing at the top that gives an option to change User Profile.
Not using any export presets.
Hi Jay
I dont see anywhere what version of MC First you are using..... the latest is 2024.3.
MC|First store the projects in your user My documents>MC First Avid Projects so check and make sure you have full permission on this folder. Do a get info and make sure it is set to read/write
User guide - page 40
Avid Projects and Avid Users Folders
https://resources.avid.com/SupportFiles/attach/MC_FirstUserGuide.pdf
Hi Marianna,
I am using version 2024.2 (for some reason, Avid Link not giving me the option to upgrade to .3)
I checked and that folder does give permission to read/write.
I actually figured it out. I found the settings folder on my Mac and threw out anything that could be corrupted: all files/folders with my name on it, MC State, any settings folder/file.
Avid First is free so it's not like I destroyed anything.
Lo and behold, somewhere in there something was corrupted but Avid rebuilt it when I launched again and now I am able to export.
Hi! Where did you find your settings folder and what did you delete. I know I'm on windows but I'm sure I can find it if you guide me
Conor Mulgrew: Hi! Where did you find your settings folder and what did you delete. I know I'm on windows but I'm sure I can find it if you guide me
Marianna:https://resources.avid.com/SupportFiles/attach/MC_FirstUserGuide.pdf
Take a look at pages 389-392 of the user guide for which settings to delete and how to do it.
