Hi
Installed media composer version 2024.2 and have an issue with picture output via AJA Kona LHE card.
Normally when appling colour correction for instance you can see in real time the changing effects both within avid and on the external monitor. Now the external monitor is not updating unless you nudge the timeline by a frame.
Also same if you toggle between layers on a timeline for instance to display a graphic or not on the output.
Sometimes does it once but then stops until the timeline is nudged along and the output catches up again.
Could be AJA drivers now dont work with latest media composer of course or could be media composer itself.
Just a thought: is render on the fly turned on?
