Hey, am getting a strange text UI behaviour when I rename tracks, they look like this:
I found a work around by checking the "Show Track Names" and it displays correctly as it normally would, but unchecked it looks like the above. Is it a setting error or curious if anyone else has experienced? Thank you!
Running a Mac Studio M1 Ultra 64gb RAM, OS Monterey 12.7.3, Blackmagic UltraStudio 4K, Desktop Video Version 12.4, Avid Media Composer 2024.4 and with an Edit Share server with Edit Share Connect v2022.2.1
Aaron Howell: Hey, am getting a strange text UI behaviour when I rename tracks, they look like this: I found a work around by checking the "Show Track Names" and it displays correctly as it normally would, but unchecked it looks like the above. Is it a setting error or curious if anyone else has experienced? Thank you! Running a Mac Studio M1 Ultra 64gb RAM, OS Monterey 12.7.3, Blackmagic UltraStudio 4K, Desktop Video Version 12.4, Avid Media Composer 2024.4 and with an Edit Share server with Edit Share Connect v2022.2.1
Hi Aaron,
Can you shoot the step by step pocedure and we will try to reproduce it.
Ajay
Thank you for the help:
1- created a group with mulitple cameras and audio
2- switched the timeline to source mode
3- renamed tracks A1-A7 with custom name by right-clicking the track and selecting "Rename Track...", typring in name and then hitting "OK"
4 - the name displays as above with the error, but under the timeline hamburber menu, I can select "Show Track Names" and it displays correctly.
Quick note I tested this with a timeline and it is displaying correctly with or without "Show Track Names" selected, so it might just be with multicam clips on the source side?
Thank you!!
