Latest post Fri, Mar 22 2024 11:44 AM by Robert Martindale. 2 replies.
  • Thu, Mar 21 2024 4:16 PM
    • Adrian Redmond
    • Joined on Wed, May 28 2014
    • Posts 302
    • Points 4,180
    Disable automatic invocation of Trim Mode?
    I very rarely use the Trim mode editor and when I do, I usually select it myself. Therefore it is a constant irritaion that MC automatically changes me into Trim mode when I don't want it. FGor example, if I have the cursor over a clip and press the "Go to next edit" shortcut, the cursor moes to where I want it and the system goes automatically into trim mode. If I don't want this (which is usual) I have to manually deselect trim mode - so having this mode offered to me 100 times a day when I don't want it far outweighs few occasions when automatic invocation might be useful. Is there any way to ask MC not to do this?
    Avid Media Composer v. 8.5.3. with Symphony Option on HP Z820 Dual Intel E5-4650L 8-core HT 2.6GHz CPU with 256GB RAM (192GB available to OS), NVidia Quadro... [view my complete system specs]
    Adrian Redmond
    Owner / Producer / Editor
  • Thu, Mar 21 2024 7:25 PM In reply to
    Re: Disable automatic invocation of Trim Mode?
    You should be aware there are two different ways to get the the next cut point. GoTo Next/Previous will take you there AND put you in trim mode, whereas traditional FFW/REW (<< / >>) wil take you to the previous/next cut point without invoking trim mode.
  • Fri, Mar 22 2024 11:44 AM In reply to
    go to next event, rather than go to next edit, will do what you want
    I9-NVidia3060-160ram-WIN11PRO-MC23.12-NewBlueFX-Photoshop-Shutter Encoder-Boris Continuum 12.5-VLC Player [view my complete system specs]
