Latest post Tue, Mar 26 2024 2:58 PM by ufy. 9 replies.
Page 1 of 1 (10 items)
  • Wed, Mar 20 2024 8:22 AM
    • ufy
    • Joined on Mon, Jan 5 2009
    • Posts 5
    • Points 55
    Avid Media Composer 2024 Audio Issue (Alternating L/R - Centered
    I found a strange issue in the 2024 version.
    I imported/transcoded my sound files but my user setting was Alternating L/R.  i changed it back to CENTERED and all of the sudden the audio quaility dropped. I sounded like the software changed the EQ and i lost the low freqs - basically the bass from the audio.
    I deleted 2024 and went back to 2023.12.1 which solved the issue.
    Did anyone else run into this issue?
    Daniel
  • Wed, Mar 20 2024 7:35 PM In reply to
    Re: Avid Media Composer 2024 Audio Issue (Alternating L/R - Centered
    ufy:
    Daniel
    Hi Daniel,
    if you will be needing to troubleshoot MC version 2024. Just shoot me a direct email and I will start a case for you so that the team can check and assist.
    My direct email is [email protected]
    Ajay
  • Thu, Mar 21 2024 1:47 AM In reply to
    Sounds like a phase shift or phase inversion issue.
    Media Composer Symphony | PT Ultimate | Win11 HPZ | OSX MBP [view my complete system specs]
  • Thu, Mar 21 2024 2:43 AM In reply to
    Yes, it does sound like cancellation was occuring once he went back to "mono" and the audio was summed.  Low frequencies are more easily cancelled.  What does listening to only a single channel sound like in mono?  Then add the second channel and see what happens.  Some Izotope plugins have phase inverter capability.
    2019 MacPro 3.3GHz 12-core Intel Xeon, AMD Radeon Pro W5700X, 96GB RAM, Ventura, Sonnet M.2 8x4 NVME PCIe card [view my complete system specs]
  • Thu, Mar 21 2024 7:38 AM In reply to
    • ufy
    • Posts 5
    • Points 55
    Hi Ajay,
    Thanks for your reply. i email you directly.
  • Thu, Mar 21 2024 8:07 AM In reply to
    • ufy
    • Posts 5
    • Points 55
    Just a quick update on this.
    I had the sound issue onl 3.5 GHz 6-Core Intel Xeon E5 Processor but dont seem to have the issue on Apple M1 Chip.
    Currently i dont have any audio plug ins installed.
  • Thu, Mar 21 2024 8:09 AM In reply to
    • ufy
    • Posts 5
    • Points 55
    It sounded the same when i selected single channel if i remember correctly.
    Currently i dont have izotope plugins.
    The issue dont seem to occur on M1 Chip.
    Daniel
  • Thu, Mar 21 2024 12:03 PM In reply to
    • Posts 12,146
    • Points 262,400
    • ! Avid Employee
      !Avid Customer Advocate
      Avid Beta Moderators
      ForumsAdministrator
      Moderator: Edit on Demand
      Moderator: SSAI PHAI
    ufy:
    Daniel
    This hasnt surfaced Daniel.....
    quick question....
    When you went back to 2023.12.1 - did you use the same sound files that were L/R and change back to center in 2023.12.1?
    Sr. Director | Customer Experience and Community [view my complete system specs]
  • Thu, Mar 21 2024 8:06 PM In reply to
    the Standard 1-band EQ effect also has a phase inversion option.
  • Tue, Mar 26 2024 2:58 PM In reply to
    • ufy
    • Posts 5
    • Points 55
    Hi Marianna,
    Yes i did used the same files and same project.
