Latest post Thu, Mar 14 2024 11:20 PM by Glenn Sakatch. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Mar 13 2024 11:27 AM
    • Rory T
    • Joined on Wed, Mar 21 2018
    • Posts 175
    • Points 1,985
    Expert Render Failing - Some Effects not Recognized
    Edit:
    Strange issue that I cannot get to the bottom of.  I have a sequence with some Sapphires and other effects in it.  Editor complained that he cannot do an expert render but a full render works with out issue.  This would suggest there is a corrupt effect in there but all the divide and conquer and proving unsuccessful.
    Even going to a section where there are no effects and marking in and out still give the same error when trying to do an expert render, not ever a frame!  We've tried on several machines and it still the same.  Media Composer 2022. 4, 2022.7 and 2022.12.7 have been tested.  Sapphires versions are matched.
    The error is "Some effects are not recognized and will not be rendered.  Do you want to continue?"  Clicking continue lists it only rendering 3 of 1000 odd effects.  It can't be a missing plugin in my mind as the full render works without issues.  We tried clearing all renders and it's still the same.
     Any help or advise please, thank you,
    Rory
  • Wed, Mar 13 2024 11:29 AM In reply to
    • Rory T
    • Posts 175
    • Points 1,985
    Re: Expert Render Failing - Some Effects not Recognized
    Edit: Fixed the formatting.
  • Wed, Mar 13 2024 6:02 PM In reply to
    Are you sure there are not any stray effects in there? Possibly audio? You could try typing "dumpfxsummary" in to the console and this will list all effects used in the sequence. You may spot one from there. Normally an unrecognised effect will have a blank icon - are there any in the sequence?
    My other advice is just do a full render if that works, real time effects wouldn't take much time to render, it would only be things like Sapphire that would need a full render and that would be happening with an expert render anyway, I doubt you're saving much time by ignoring the real time stuff.
    You can always modify the clips that expert render chooses using the "modify selection" button and shift+clicking the effects you don't want to include in order to, for example, only expert render Sapphire effects but that sounds like a lot of faff when you could just render the whole thing.
    Andi
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 64GB RAM Win 10 Pro MC Ultimate 2022.10 MacbookPro 15 2019 6 core 2.6GHz i9 32GB... [view my complete system specs]
  • Thu, Mar 14 2024 12:13 PM In reply to
    • Rory T
    • Posts 175
    • Points 1,985
    The answer is "just do a full render" but that does not seem to satisfy the client, so I just thought I'd ask here in case the answer is simple.  It is odd though, the assistant cut all the audio off and it was still the same error and then cut all the video off, same again.
    This would suggest the sequence is sick to me, so create a new sequence and cut everything over but it is still the same.  :/ In regards to dumpfxsummary, if a full render works surely that implies all the effects are accounted for? Cannot see any blank effect icons but only after a brief scan, again I feel this should error in full render too if that was the case though
    We are only short of being asked to pick each effect off one by one and try and try again...life is too short for that!
    Here is the fxdump, nothing looks out of place to me:
    3280 total effect(s) found.
    381 Segment Effect(s): (378 Video, 3 Audio)
    780 Transition Effect(s): (20 Video, 760 Audio)
    265 Motion/Timewarp Effect(s)
    5 Track effect(s): (0 Video, 5 Audio)
    1849 Audio Pan/Volume effect(s)
    Some of the effects are nested inside of other effects. Total nested effects: 68 (68 Video, 0 Audio).
    1120 precompute reference(s) found.
    ----- Effect breakdown by effect type: -----
    (1) AVX2 Effect : 3D MatteKey
    (44) AVX2 Effect : 3DWarp
    (3) AVX2 Effect : Resize
    (1627) Audio Pan/Volume (Clip Gain)
    (106) Audio Pan/Volume (Clip Pan and Clip Gain)
    (2) Audio Pan/Volume (Clip Pan and Volume)
    (95) Audio Pan/Volume (Clip Pan)
    (19) Audio Pan/Volume (Volume)
    (3) AudioSuite : Time Compression Expansion
    (760) Blend : Audio Dissolve (AVX2)
    (17) Blend : Dissolve
    (8) Generator : SubCap (AVX2)
    (1) Generator : Timecode Burn-In (AVX2)
    (24) Image : Color Adapter
    (2) Image : Color Correction ((CC Effect))
    (1) Image : Color Correction ((Src))
    (17) Image : Paint Effect
    (29) Image : Stabilize
    (5) Image : Submaster
    (20) Key : AniMatte
    (208) Key : Matte Key
    (4) Mono EQ : Channel Strip
    (12) Motion Effect
    (1) Sapphire Distort : S_WarpPerspective (AVX2)
    (1) Sapphire Lighting : S_Glow (AVX2)
    (1) Stereo EQ : Channel Strip
    (16) Timewarp : Timewarp
    (16) Title : Title
    ----- Effect Plug-in Summary: -----
    8 Plug-in types found. (779 total occurrences)
    (3) AudioSuite : Time Compression Expansion (Time Compression Expansion ### AudioSuite) (audio.as.1147758441.1416446789.1413694808)
    (760) Blend : Audio Dissolve (AVX2) (AVX2AudioDissolve ### Blend ### AVX2 ### Version 1.0) (BLEND_AUDIO_DISSOLVE)
    (8) Generator : SubCap (AVX2) (SubCap ### Generator ### AVX2 ### Version 1.0 ### Avid Technology Inc.) (E4FE520A-B815-447F-A969-2D5E1C5F6C14)
    (1) Generator : Timecode Burn-In (AVX2) (Timecode Burn-In ### Generator ### AVX2 ### Version 1.0 ### Avid Technology Inc.) (169317AB-ACAA-416F-84CE-249BFE0B09ED)
    (4) Mono EQ : Channel Strip (Channel Strip ### Mono EQ ### AAX) (audio.rtas.1096173892.1130910580.1129140820)
    (1) Sapphire Distort : S_WarpPerspective (AVX2) (S_WarpPerspective ### Sapphire Distort ### AVX2 ### Version 15.539 ### GenArts, Inc.) (BE665684-E9F5-00A5-A535-B9FE80107FDA)
    (1) Sapphire Lighting : S_Glow (AVX2) (S_Glow ### Sapphire Lighting ### AVX2 ### Version 15.539 ### GenArts, Inc.) (F668F0CE-0E8B-009A-9A9F-05F7FF519869)
    (1) Stereo EQ : Channel Strip (Channel Strip ### Stereo EQ ### AAX) (audio.rtas.1096173892.1130910580.1129534036)
  • Thu, Mar 14 2024 2:38 PM In reply to
    Yeah, weird. Only thing I'd note from this is the presence of nested effects. Have you stepped in to those ones? Avid always did have trouble rendering things inside a nested stack.
    What happens if you manually render those effects after stepping in and then step out and try another expert render?
    Clients being unreasonable? Never! Stick out tongue
    Andi
  • Thu, Mar 14 2024 5:56 PM In reply to
    • Rory T
    • Posts 175
    • Points 1,985
    I've done a full render in to out and then change an effect ever so slightly and tried an expert render and I still get the same issue.  I just though I'd ask.  And I learned about dumpfxsummary and dumpfxlocation and that you have to shift click when modifying the clip renders so it wasn't a wasted effort.
    Thanks for the reply,
    Rory
  • Thu, Mar 14 2024 11:20 PM In reply to
    A bit off topic, but I have to ask...what does the client care what type of render you do as long as the show plays out properly?
    Honestly i rarely worry about render time any more.  Everything is soooo much faster than it was 30, or ev 20 years ago.
    Current Avid-Z390 Win 10 Intel i9 64gig ram Nvidia A5000 MC current level - Win 10 64 Gig Ram [view my complete system specs]
