I'm currently running MC 2023.12 on my 2023, 16" M2 MBPro with no problems at all. But I'd like to add I/O gear to send picture to a client monitor, and sound to external speakers. In the paast, I've used AJA and Blackmagic devices, but I'm seeing some feeedback online that the currrent versions aren't compatible with MC on Apple silicon. And I know Avid has discontinued the Artist I/O boxes. Anybody have experience with this?
We had issues whereby having I/O connected to MC on an Apple Silicone system caused MC to crash/hang/drop audio.
The root causes included bugs in our open IO code and Blackmagic's desktop video setup driver.
You 'should' be okay, and if there are issues they will be fixed. The alternative is running your client monitor through HDMI and setting that up as a full screen playback device within Media Composer
For now, we have this communication:
Blackmagic has released a new Desktop Video driver v12.8.1 to resovle the hang when starting playback on MC.
https://www.blackmagicdesign.com/support/
This software includes everything you need to set up your DeckLink, UltraStudio and Intensity for video capture and playback with your computer.
Apple silicon and Intel Macs:
Intel Macs only:
A system with ample memory is strongly recommended.
Desktop Video has been tested on the following platforms:
Supported kernels older than 3.12 require an extra step after plugging the device in. You must tell the kernel to rescan the PCI bus using the following command:
# sudo sh -c 'echo 1 > /sys/bus/pci/rescan'
Kernel 3.12 and later support hotplug without the need for any extra steps.
Several different package formats are supplied:
Full release notes including installation instructions are available in the ReadMe.txt found in the downloadable tar archive.
If you have installed the drivers prior to installing any of these applications, we recommend that you uninstall and reinstall the drivers. This will ensure that all relevant components are installed in their required locations.
Please check www.blackmagicdesign.com for additional information on third party software compatibility and minimum system requirements.
Some applications may use third party code under license. For details please refer to the included "Third Party Licenses.rtf" document.
© 2024 Blackmagic Design Pty. Ltd. All rights reserved. 'Blackmagic Design', 'Blackmagic', 'Blackmagic Cloud', 'DaVinci Resolve', 'Fusion', 'Fairlight', 'Ultimatte', 'HyperDeck', 'DeckLink', 'HDLink', 'Videohub', 'Intensity' and 'Leading the creative video revolution' are registered trademarks in the US and other countries. All other company and product names may be trade marks of their respective companies with which they are associated.
Updated February 14, 2024.
Freelance Film Editor | Technical Expert @ Avid
[email protected]
My Equipment & System Specs
