Hi guys,I've just finished an edit and need to export an AAF or OMF for soundmix.However, when I try to export the AAF I get this following message:Exception: std::exception, what: ACF call failed: m_pWriter->BeingWrite(), error code 0x0000008, file e:\ws2\workspace\MC\Release_Installer_Git\\Win_Build\coresw\ame\src\msm\AMAWriter\AMAFileWritebackSession.cpp line 134Any idea how to fix it?An OMF would work as well but when I try to export OMF I get the message 'OMF Export is not supported in HD projects'. What does that mean?This is so frustrating.Appreciate any help. Thank you.
Hi FilippoM,
I see that you already have an open case: 04755699 which is already handled by one of our Video Editors. I will make a follow up on the case so they may assist you with this issue.
Thank you very much!
Inocencio
In your setting format tab: switch to an SD project raster to do an OMF export (remember to switch format bac after)
Re the AAF export try divide and concur.
sub sequence off a small section (try it with a few different parts of the timeline)
Try removing tracks and exporting.
Basically wittle it down till you get an export that may point to a problematic audio media file.
T 07581 201248 | E [email protected]
Thanks isamson,Unfortunately what they advised me to do doesn't work. Could you make another follow up?Thank you
I regularly export OMF and AAF in my workflows. A few hiccups to consider: remove any muted tracks from your timeline (or unmute them); Commit Multicam Edits so there are no group clips in the timeline. As mentioned, for OMF you need to switch to an SD project.
