Latest post Wed, Feb 28 2024 2:47 PM by oklaroma. 4 replies.
  • Sat, Feb 10 2024 9:51 AM
    • FilippoM
    • Joined on Wed, Mar 23 2022
    • Posts 24
    • Points 350
    Error exporting AAF and OMF
    Hi guys,
    I've just finished an edit and need to export an AAF or OMF for soundmix.
    However, when I try to export the AAF I get this following message:
    Exception: std::exception, what: ACF call failed: m_pWriter->BeingWrite(), error code 0x0000008, file e:\ws2\workspace\MC\Release_Installer_Git\\Win_Build\coresw\ame\src\msm\AMAWriter\AMAFileWritebackSession.cpp line 134
    Any idea how to fix it?
    An OMF would work as well but when I try to export OMF I get the message 'OMF Export is not supported in HD projects'. What does that mean?
    This is so frustrating.
    Appreciate any help. Thank you.
  • Wed, Feb 14 2024 6:00 PM In reply to
    • isamson
    • Joined on Wed, Feb 17 2016
    • Posts 43
    • Points 360
    • ! Avid Employee
      Avid Customer Service
    Re: Error exporting AAF and OMF
    Hi FilippoM,
    I see that you already have an open case: 04755699 which is already handled by one of our Video Editors. I will make a follow up on the case so they may assist you with this issue.
    Thank you very much!
    Inocencio
    Hi guys,
  • Wed, Feb 14 2024 7:44 PM In reply to
    In your setting format tab: switch to an SD project raster to do an OMF export (remember to switch format bac after)
    Re the AAF export try divide and concur.
    sub sequence off a small section (try it with a few different parts of the timeline)
    Try removing  tracks and exporting.
    Basically wittle it down till you get an export that may point to a problematic audio media file.
    T 07581 201248 | E [email protected]
  • Fri, Feb 16 2024 2:58 PM In reply to
    • FilippoM
    • Posts 24
    • Points 350
    Thanks isamson,
    Unfortunately what they advised me to do doesn't work. Could you make another follow up?
    Thank you
  • Wed, Feb 28 2024 2:47 PM In reply to
    • oklaroma
    • Joined on Thu, Apr 12 2018
    • Posts 8
    • Points 105
    I regularly export OMF and AAF in my workflows. A few hiccups to consider: remove any muted tracks from your timeline (or unmute them); Commit Multicam Edits so there are no group clips in the timeline. As mentioned, for OMF you need to switch to an SD project.
