I creamted a program in Media Composer 2023.8.1. Everything edited just fine.. After exporting the program .the following message appeared.
We can't plaly the audio for ________, It's encoded in pcm format which isn't supported. Yu can still watch the video. Learn more about codecs.
Is there a way to add the PCM codec?
[email protected]
Ron
If it is just a few clips, how about converting those in Shutter Encoder into a format avid works with?
You likely export to something like MP4 from Media Composer? If so, many software players won't play back h264 video with PCM audio in an mp4 container (even though MC will allow you to export is that way). Either use AAC upon export, or use the MOV container to export h264 with PCM audio.
