Latest post Tue, Aug 1 2023 2:18 PM by Job ter Burg. 13 replies.
Page 1 of 1 (14 items)
  • Wed, Jul 19 2023 3:11 PM
    • Pol
    • Belgium
    • Posts 283
    • Points 3,785
    group or nest audio tracks
    These days cutting reality TV is very complex.
    We have 50 seperate audio tracks. It's very annoying to edit with that amount of audio tracks.
    We can group video clips, so I wonder if there's a technique to also group audio tracks?
    Nesting audio tracks like I could nest video tracks would also be an option.
    Everything to keep the timeline audio tracks limited would be nice.
  • Thu, Jul 20 2023 8:54 PM In reply to
    • dlogneb
    • Joined on Wed, Aug 27 2014
    • Posts 286
    • Points 3,440
    Re: group or nest audio tracks
    50 separate tracks?  For what?  I'm curious.  I imagine a bunch of diff mics... but 50???
    Avid MC 2022.10 & 2022.7 Mac Os Monterey (12.6.1 & 12.3.1) MacStudio Apple M1 Ultra 128GB [view my complete system specs]
  • Wed, Jul 26 2023 4:49 PM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Dallas TX
    • Posts 2,216
    • Points 23,845
    iIf you imagine all the cams they use and they all have descrete mics plus main mics music sfx It adds up fast
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Wed, Jul 26 2023 11:04 PM In reply to
    I'm a bit confused. Can't you just make a sequence of audio only tracks and then group them normally? I just did that with a 28 track sequence and I ended up with a group clip with all of the audio available in the usual way via the dropdown menu or up/down arrows. The main A cam had 4 audio tracks so I ended up with a group displaying 4 tracks of audio but with 28 tracks available.  It just didn't have video. Maybe I am misunderstanding your question...
    Andi
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 64GB RAM Win 10 Pro MC Ultimate 2022.10 MacbookPro 15 2019 6 core 2.6GHz i9 32GB... [view my complete system specs]
  • Thu, Jul 27 2023 8:32 AM In reply to
    • Pol
    • Belgium
    • Posts 283
    • Points 3,785
    That's a great tip! Thanks.
  • Fri, Jul 28 2023 8:09 AM In reply to
    • Pol
    • Belgium
    • Posts 283
    • Points 3,785
    But stil not what I want to achieve.
    If I group the audio, I have to choose wich audio channel to monitor. I want to hear all tracks but want to combine all the audio in 1 track for faster editing.
    Regards,
  • Fri, Jul 28 2023 11:11 AM In reply to
    • Antonio Lara
    • Madrid. Spain
    • Posts 133
    • Points 1,705
    Probably you have already thought about it, but you can do an audio mixdown, as a sort of temporary monitor track. Then add it to all the others to follow the group route, but choosing this new one to monitor them all.
    As a teacher: Media Composer 8 software only, in a pc world. www.urjc.es And also in a MacBookPro 17 mid 2010. Mac Os 10.11.6 [view my complete system specs]
  • Fri, Jul 28 2023 12:48 PM In reply to
    Pol:
    Oh, in that case yes, I agree with Alara - just do a mixdown and add it to the group. I feel like 50 mics all mixed down in to one is not going to sound amazing though, especially if there is some offset.
    Andi
  • Fri, Jul 28 2023 3:23 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 1,152
    • Points 14,605
    I've experimented with this by mixing down tracks  to a 5.1 or 7.1 track. This will play out the multiple tracks on one sequence track (5.1 or 7.1).
    Problem comes when you want to dive in and alter some level on one of those tracks. There's no way I've found of doing this in the Audio Mixer tool. You can split this track back to mono and then adjust as necessary. Problem is there's not a command to put these mono tracks back to multichannel.
    The only way is to repeat the audio mixdown again, so this gets rather messy.
    HP Z800, HP G9 Fury, SonnetFusion RAID, Mojo DX, Decklink 4K, Ultrastudio 3G/4K, Symphony 2018 & 2023, Boland BVB25 OLED, JVC DTV1910 HD CRT, Eizo... [view my complete system specs]
  • Mon, Jul 31 2023 8:39 AM In reply to
    • Pol
    • Belgium
    • Posts 283
    • Points 3,785
    All very good tips but unfortunately not exactly what I am looking for.
    A mixdown to a mix track is to be avoided because everything still goes to protools. I don't want to saddle the audio mixer with a mix track.
    And if he has to search all the original tracks again, he also loses a lot of time.
    Ideally there would be a bus system in timeline. An aux track that can group several other audio channels.
    Regards
  • Mon, Jul 31 2023 12:15 PM In reply to
    • Bruno M
    • London, UK
    • Posts 1,152
    • Points 14,605
    If it's any consolation, they've just introduced groups on the Fairlight page of Resolve 18.5.
  • Tue, Aug 1 2023 2:17 AM In reply to
    • hbrock
    • Bainbridge Island, WA
    • Posts 5,586
    • Points 65,025
    • Moderator: MCA Mac
    Do all the tracks need to go to ProTools from your timeline or can the sound editor conform tracks based on your timeline as needed?
  • Tue, Aug 1 2023 8:05 AM In reply to
    • Pol
    • Belgium
    • Posts 283
    • Points 3,785
    Yes, when the edit is finished, we export a AAF or Protools project from Media Composer.
    There's no budget in audiopost for relinking to the original audio files.
  • Tue, Aug 1 2023 2:18 PM In reply to
    I get what you mean, but you would not need to relink to the originals. If you import all tracks into MC and were to cut with a mixdown, expanding that to the full ISO tracks in Pro Tools literally takes seconds rather than minutes. This doesn't change the fact that you as an editor may want or need to dive into the ISO's on a regular basis. That still won't change the practice of expanding the tracks in Pro Tools.
    Obviously, if in your workflow, you are essentially cutting the dialogue tracks for the final mix, then this may not make sense, of course.
    Just clarifying that such an expansion is even simpler than a conform.
    Media Composer Symphony | PT Ultimate | Win11 HPZ | OSX MBP [view my complete system specs]
