Latest post Mon, Aug 21 2023 4:43 PM by fiendish. 7 replies.
  • Wed, Jul 19 2023 4:04 AM
    • Dalida
    • Posts 59
    • Points 690
    Undesirable Zoom Using Framex in a Multicam Group.
    Hi everyone,
    I have noticed an strange behavior with multicam groups.
    Working with DNxHR LB (1920x1336) media in a project 1920 x 1080. I applied Frame Flex to all clips to size matches project raster. Works great. But when I created a multicamera group, a clip was resized more than what I have applied in the FrameFlex (looks like a zoom).
    if I load the group in the Source Monitor the clip appears with the zoom. If I matched frame the group, the clip is loaded in the Source Monitor and it is ok. The sequence is ok too.
    This happens only with some clips, nor with all.
    Any ideas why this is happening?
    Working with 2023.3.1
    Thank you in advanced.
  • Thu, Jul 20 2023 8:52 PM In reply to
    • dlogneb
    • Joined on Wed, Aug 27 2014
    • Posts 286
    • Points 3,440
    Re: Undesirable Zoom Using Framex in a Multicam Group.
    I believe this is because one of your group clips has a frameflex zoom and one doesn't.   As far as I remember, group clips can only have one frameflex format, so if you have two different formattings in the group one of the angles will be incorrectly formatted.
    Maybe it's not even that, and just sucks at frameflex entirely?
    But, in anycase, if you edit from the "zoomed in clip" you will find it looks fine in your sequence I believe.  That's my memory.
    Avid MC 2022.10 & 2022.7 Mac Os Monterey (12.6.1 & 12.3.1) MacStudio Apple M1 Ultra 128GB [view my complete system specs]
  • Thu, Jul 20 2023 11:22 PM In reply to
    • Dalida
    • Posts 59
    • Points 690
    Thank you for your answer.
    In fact, both clips were applied with the same FrameFlex Setting: Size matches project raster.
    And making more tests, sometimes, the sequence is affected with the extra zoom too.
    I created a cse in Avid so as soon as I have the final answer, I let you know but it seems that it is a bug
  • Mon, Jul 24 2023 6:21 PM In reply to
    • Dalida
    • Posts 59
    • Points 690
    Justo to updated this case. Here is the answer fron Avid:
    "The issue that you're getting is now confirmed as bug under MCCET-5133 bug number.
    We will keep you updated when there is a news from our engineering."
    Thank you all.
    Wink
  • Thu, Aug 17 2023 1:57 PM In reply to
    • Idoc
    • Joined on Tue, Jul 12 2022
    • Posts 4
    • Points 40
    I've found a workaround for this problem. I create a group using a timeline, so cam1 on track 1, cam2 on track 2 and so on but the tracks must begin at the same point, no filler at top of the sequence. At this point, right click and create group. I hope to help
  • Thu, Aug 17 2023 11:34 PM In reply to
    • Dalida
    • Posts 59
    • Points 690
    Hi Idoc,
    I tried your workaround. It implies more steps to achieve the group without the strange behavior of the FrameFlex but it really works.
    Thank you very much for you suggestion. I will take it into account.
    Dalidá
    Yes
  • Fri, Aug 18 2023 11:04 AM In reply to
    • Greyo
    • Wales
    • Posts 526
    • Points 7,075
    We discovered this is because the FrameFlex occurs after the multicam in the processing pipeline of Avid which is why its fine on the sequence. To get around this when transcoding proxies from bigger rasters to HD we burnt in the frameflex which then allowed the clips to scale correctly in the multicam
    Windows XP Duel Xeon CPU 3.06GHZ 1.00GB of Ram Nividia Quadro NVS with AGP8X [view my complete system specs]
  • Mon, Aug 21 2023 4:43 PM In reply to
    • fiendish
    • Posts 534
    • Points 6,505
    Yes great suggestion Idoc - I had exactly the same problem in 2022.10 and your workaround has fixed the problem for me too.
    Many thanks!
    z840 dual [email protected] / 64GB ram / Quadro M5000 / MC 2020.10 / BM Decklink Studio 2 // i7-2600k Home Build / 8GB ram / MC 2018.12 xw8600 Dual Quad... [view my complete system specs]
