Latest post Fri, Apr 28 2023 10:27 AM by Robert Martindale. 6 replies.
Page 1 of 1 (7 items)
  • Sun, Apr 23 2023 2:28 AM
    Just updated the Nvidia card..how to check if it helps?
    Moved from an Nvidia 1070ti with 8g ram to an RTX3060 with 12g ram......they use the same driver, which is not the approved driver AVID lists....Everything works but I would like to see if the GPU is sharing load, etc.
    How is it possible to see if MC is using the new card correctly?  The RTX3060 is listed as approved on the AVID configuration document.
    I9-NVidia3060-160ram-WIN11PRO-MC24.6-NewBlueFX-Photoshop-Shutter Encoder-Boris Continuum 12.5-VLC Player [view my complete system specs]
  • Sun, Apr 23 2023 6:50 PM In reply to
    Re: Just updated the Nvidia card..how to check if it helps?
    If you open the Avid Console immediately after you open a project, the GPU should be detected and listed.
    Just remember that Avid MC is not very reliant on the GPU with some exceptions. It is mostly a CPU bound application.
    MC 2023.8, W11, ASUS z690m, Intel 13900K, MSI 4090 Suprim Liquid, 128GB RAM, Samsung 980 Pro M2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2019, Ventura... [view my complete system specs]
  • Sun, Apr 23 2023 7:53 PM In reply to
    THank you for that information....this is what Console shows when opening a new project:
    Set persistent image cache limit: 1000.0 MB in D:/AVID MEDIA CACHE
    WARNING: Requested LocateBuffer size 16384MB is the same as current size 16384MB.
    Local Disk Cache - PurgeDataToMaintainQuota:
    Bytes Purged: 0d
    Elapsed Time Milliseconds: 1
    Bytes Purged: 0d
    Distributed Processing - Reset SubmitQuery cache
    Destroying Bin Container without closing
    qm2b is enabled
    Reloading plugin: acpl_lut.acf
    Reloading plugin: BCC_AVX2_MC.avx
    MSMRescan() all took: 0.034000s
    Nothing there about a GPU...is something wrong?
  • Sun, Apr 23 2023 7:56 PM In reply to
    3060 works just fine with MC.
    I have 3060 6G at laptop and 12G on desktop.
    Both working like a charm.
    Remember MC doesn't use that much of the card and in some cases this is good.
    Check the process manger to see where and how MC uses the card.
    Desktop
    Asus Ζ690 TUF Gaming WiFi D4|i5 12600K|Corsair 128G DDR4|Asus 3060 12GB|Samsung 980 500GB(OS)|2X1TB Samsung 980 RAID 0|W11 Pro
    Laptop
    MSI Katana GF76 11UE (i7 11800H|Nvidia 3060|Crucial 64G DDR4)|W11 Pro
    NLE
    DR Studio 19|MC 2024.2
    VDIM
  • Sun, Apr 23 2023 8:37 PM In reply to
    Thank you...it works for sure..i just want to make sure it works as well as it can.
    What driver are you using?
  • Mon, Apr 24 2023 5:22 AM In reply to
    IS THIS GOOD NEWS?...
    ACPL GPU Memory Pool Capacity: 6144 MB
    ACPL GPU Memory Pool Host Capacity: 1952 MB
    ACPL GPU Private Memory Pool Capacity: 5376 MB
    ACPL GPU Private Memory Pool Host Capacity: 0 MB
    ACPL GPU VRAM Capacity: 12288MB
    ACPL GPU Driver: 531.61
    ACPL GPU Card Model: NVIDIA GeForce RTX 3060
    Newer CPU<->GPU bus speeds detected (2.0687) (WHAT DOES THIS MEAN?)
  • Fri, Apr 28 2023 10:27 AM In reply to
    Newer CPU<->GPU bus speeds detected (2.2459)
    change after the new intel I9 cpu was put into service...what does this 2.**** number mean?  Is a bigger number better?  anyway...MC does seem to be happy with the RTX3060
