Latest post Thu, Feb 16 2023 6:21 PM by dew. 2 replies.
  • Sat, Feb 11 2023 2:22 AM
    • dew
    • Joined on Tue, Feb 27 2007
    • Posts 653
    • Points 8,270
    advice to resize an edit for instagram
    So I have a standard 1920x1080 15 sec ad I need to make into a 1080x1350 size for a instagram post. As I don't want to start from scratch and rebuild this edit, can anyone give me thoughts for the best workflow to do make this change? I did do a mixdown and use frameflex to make an adjust but is there a way to say change the sequence so I can make some changes to fit some of the media in the frame? I hope I have explained this in a understanding way.  Or is there a way to set the grid to the instagram size so I can just rework the edit in the original sequence?
  • Sat, Feb 11 2023 4:28 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,514
    • Points 18,890
    Re: advice to resize an edit for instagram
    Easiest way:
    Create a new project 1080x1350.
    Bring a copy of your sequence into the new project
    For each clip on the timeline, adjust the Frameflex aspect ratio to 0.8:1 (4:5), Pillarbox/Letterbox (Not stretch)
    Reframe as needed
    There are other tricks you can use, for example saving the 1080x1350 as a preset (when you create the project) so you can simply switch to it within your existing projects using mask margins.
    i9 12th generation, GeForce 3070, 64GB RAM [view my complete system specs]
  • Thu, Feb 16 2023 6:21 PM In reply to
    • dew
    • Posts 653
    • Points 8,270
