Latest post Mon, Jan 16 2023 4:39 PM by Verne Mattson. 3 replies.
  • Wed, Dec 28 2022 11:42 AM
    • gorky
    • Joined on Wed, Nov 16 2005
    • Posts 155
    • Points 1,900
    MC 2022.12 problem with Baselight plugin and render bar.
    After installing new 2022.12 version I can't open sequences with Baselight plugin, Avid shutting down. If I opening sequence without Baselight plugin and drop new plugin on any clip after that I can open any sequence. But Avid can't open sequence and activate Baselight plugin simultaneously. There is no such problem in previous MC versions.
    And render bar is blinking upon render process on any fx after one hour or more of work.
    I am working in Macos 12.6.2.
    MacBook Pro (16-inch, 2019), 2,4 GHz Intel Core i9,32Gb RAM, AMD Radeon Pro 5500M 8Gb, OSX 10.15.3 [view my complete system specs]
  • Wed, Dec 28 2022 12:43 PM In reply to
    • damien78
    • Joined on Tue, Jan 7 2014
    • Geneva
    • Posts 54
    • Points 670
    Re: MC 2022.12 problem with Baselight plugin and render bar.
    [UPDATE] Problem confirmed by Filmlight. I have also opened a case with Avid 04558894
    Exact same problem here.
    Uninstalled MC22.10, install 22.12, new user profile. No specific issue, until I tried to load any previously created sequences with one instance of the Baselight Plugin, then MC crashes and exit. I tried to create a new sequence and put the Baselight FX, it works. But next time I load the newly created sequence, same trouble, it crashes MC22.12.
    I am on a supported Mac Pro 2013 with MacOS 12.6.2.
    Media Composer 2023.8.2, w/Symphony/SS/PF options, MAC STUDIO M1, 64 GB RAM, MacOS 13.6.1, BMD 4K Mini [view my complete system specs]
  • Fri, Dec 30 2022 1:00 PM In reply to
    • damien78
    • Geneva
    • Posts 54
    • Points 670
    It has now been logged by support as
    MCCET-4957 Serious Error Occurred error message (on second launch) when Baselight effect is applied to opened sequence
  • Mon, Jan 16 2023 4:39 PM In reply to
    • Verne Mattson
    • Joined on Sat, Nov 19 2011
    • Northern New Jersey
    • Posts 25
    • Points 305
    I'm seeing the same problem here. Avid 2022.12 and BLE - for me it's crashing on startup to a BLE project because it's parked on a BLE effect.  No issues on non-BLE projects.
    Thanks for submitting to support.
    2019 MacPro 16 core 96GB RAM [view my complete system specs]
