Latest post Fri, Dec 2 2022 9:26 AM by Mercer. 4 replies.
  • Wed, Nov 30 2022 4:47 AM
    • ugo1
    • Joined on Thu, Jul 13 2006
    • Italy
    • Posts 285
    • Points 3,965
    Red dot in timelime where I'm under specifications
    I started working with Prores C4K HQ files and when I use Effect cc in secondary color correction I get red dot in timeline. Where I'm under specifications?
    PC / System configuration below is current
    Regards
    Ugo
    Case: Phantek Enthoo Luxe, Motherboard: Asus Prime WS299 Sage/10G, Cpu: Core i9-10920X,Ram: 32GB Ripjaws 4, GPU: Asus Nvidia Rtx 2080 Super 8 GB, Sound... [view my complete system specs]
  • Wed, Nov 30 2022 10:07 AM In reply to
    • Mercer
    • Joined on Thu, Apr 15 2010
    • UK
    • Posts 873
    • Points 11,290
    Re: Red dot in timelime where I'm under specifications
    I believe that is drive speed. Even standard single SSD drives may not be fast enough for Prores HQ 4K, at times, with additional FX processing. Some large fast Raid drive combinations and NVME drives should be fine though. For such material and especially for grading/FX finishing I offload the conform onto internal NVME 2TB drives, 1 or which is for render and cache only.
    MC with Symphony option, 2022.10, HP ZBook 17 G5, i7-8850H 6 core/64GB ram/512 M2 ssd/Nvidia Quadro P5200/16GB/FHD, HP Thunderbolt Dock G2, BMD Ultrastudio... [view my complete system specs]
  • Wed, Nov 30 2022 11:32 AM In reply to
    ugo1:
    Are there any other colors? Yellow would indicate the system is not powerful enough, and blue would indicate the drives (or the drive connection) are not fast enough.
    Media Composer 2024.2 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Wed, Nov 30 2022 1:27 PM In reply to
    • ugo1
    • Italy
    • Posts 285
    • Points 3,965
    camoscato:
    ugo1:
    No just the red color and allclips are on NVME Pcie3 drive and I have the rendering drive on a sata III port. If I render I have no problems but is bit annoying.
    Ugo
  • Fri, Dec 2 2022 9:26 AM In reply to
    • Mercer
    • UK
    • Posts 873
    • Points 11,290
    ugo1:
    I would move this to an NVME drive, it will at least speed up rendering considerably. You may find your problem is ram - I would double that ram, at least for working in 4K. Possibly too, your Prores HQ is 50/60p? Then you are dealing with 8 x the bandwidth of HD (@ 25/30). ProresHQ, like DNxHD/R, is an optimised post codec that should have little demand on the cpu but in dealing with 4K and larger bandwidths, ram can easily be eaten up quickly for FX and processing.
