Does anyone know if there is a 999 line limit for CUEDOS formatted EDLs? Trying to export an EDL cue sheet from a sequence in Media Composer 2022.7 but it will only output up to line 999. Then it gives an error stating the number of lines that couldn't be exported. Using a different output format it will export 1152 lines without error. Unfortunately, delivable requirement is in CUEDOS format.
Hi ck123,
I'm sending this to the support team.
RalphC
Following up in case anyone else has this question. Support responded that it's a built-in limit. Exporting tracks individually or splitting a sequence into blocks is required to work around.
