Latest post Wed, Jul 27 2022 3:55 PM by Roger Shufflebottom. 37 replies.
Page 2 of 3 (38 items) < Previous 1 2 3 Next >
  • Mon, Jul 18 2022 9:32 PM In reply to
    Re: Old school editing help!
    marluc:
    If you look at the clip before mixdown you see what looks like two color adjustmen icons. One should be the noise reduction and sharpening, but that icon is either gone or covered by another. It's not a plugin.
    Could that be because you've nested something?
    Try in and out and mixdown a smaller section to test. Remove all effects, then mixdown the raw clip. Then add the first effect, mixdown again, then the second, mixdown again.
    Take note of the first mixdown you encounter the softness issue, Then you know which effect is causing the issue.
    I'm not familiar with those codecs, I would Link then Transcode to DNxHD SQ
    Editing Movie Magic.
    My Equipment & System Specs
    Media Composer Ultimate 2022.7 | Pro Tools Studio 2022.7 | Avid Play | Sibelius Artist 2022.7
  • Mon, Jul 18 2022 10:53 PM In reply to
    marluc:
    should these SD files be imported as DV25 411 or as Pro Res?
    For about 20 years I would record any really old VHS tapes and Umatic tapes to to a DV deck using the composite input. More recently SVHS out to a HDV deck. Then capture from that DV deck originally via Firewire  to DV format and later SDI to SD MXF. Sony had really good DV recording and Avid had a great DV codec .
    Not nearly so sure about this workflow these days with Apple no longer supporting QuickTime.
  • Tue, Jul 19 2022 8:07 AM In reply to
    Philip Kapadia:
    DNxHD is not available in SD projects, though.
    I'd choose ProRes over DV. Or 2:1 Meridien.
  • Tue, Jul 19 2022 10:57 AM In reply to
    • marluc
    • New York State
    • Posts 516
    • Points 6,525
    Philip,
    It is likely that's what happened....maybe.  I noticed that one ofd the icons was missing.  Whe I removed the visible one, the sharpening icon was revealed.  In the past, nesting was more complicated than just puttig two different iffects on one channel of video, but perhaps that too has changed.  I'll check that as a mixdown today.
    marluc
    DESKTOP: 27" iMac/3.5GHz Quad Core i7/ 32 GB 1600 MHz DDR3, 8GB/1TBFlash Storage/NVIDIA GTX 780M 4GB, running OS X 10.15.6 and MC Ultimate version... [view my complete system specs]
  • Tue, Jul 19 2022 12:03 PM In reply to
    Going back to the original question, I just created an NTSC 30i project, which reports as 720x486 when setting up. When attempting to export as MOV or MP4 (2022.4), the dimensions default to 'Custom, 720x496' but you can choose the correct preset from the emenu. Odd.
    iMac i5 27", 40GB RAM, OS 11.6.4 with MC 2022.7 with Symphony option, BlackMagic 4K. 2020 MacBook Air with MC 2022.7 ... and NewsCutter 7.x on Dell... [view my complete system specs]
    ACI, Dorset, UK. www.avid-companion.co.uk
  • Tue, Jul 19 2022 4:03 PM In reply to
    • marluc
    • New York State
    • Posts 516
    • Points 6,525
    Roger,  I just spent an hour on the phone with an Avid technician (in Europe) who walked me through every step of my project from ingesting to output and encountered all the problems I have described. It seems that the latest release of Media Composer does just what you describe, and I have found, and it doesn't seem to allow for interlaced video no matter what your settings are. He found the problems to be just as weird as I do, and is sending the case to the American technicians. Who kows what will result but in the meantime it is a catastrophe for me!
    marluc
  • Tue, Jul 19 2022 5:13 PM In reply to
    • marluc
    • New York State
    • Posts 516
    • Points 6,525
    I should add, this problem relates only to Mac OS Catalina, not to PC's!!
    marluc
  • Tue, Jul 19 2022 5:27 PM In reply to
    Well, Mac OS, anyway ... I'm on Big Sur, 11.6.4.
  • Tue, Jul 19 2022 7:00 PM In reply to
    • marluc
    • New York State
    • Posts 516
    • Points 6,525
    Right, Roger.  We've got to get Avid to do something about this--a patch perhaps?
    marluc
  • Wed, Jul 20 2022 1:37 PM In reply to
    Job ter Burg:
    Philip Kapadia:
    ahhhhh
    marluc:
    marluc
    You've reported it - not much more we can do I'm afraid!
    Happy that you got to the bottom of it though
  • Wed, Jul 20 2022 1:56 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,070
    • Points 49,100
    I may have missed this bit of info, but I am curious as to what tech / method was used to digitize the original files?
    And just a side note (which may have already been addressed) but DNxHR does NOT support interlace in any fashion.
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2021 iMac w Big Sur [view my complete system specs]
    Jef Huey
  • Wed, Jul 20 2022 6:06 PM In reply to
    • marluc
    • New York State
    • Posts 516
    • Points 6,525
    Jef, I canot tell you what method was used to convert the original files from 1/2 inch open reel tape, but I can tell you they were given to me in three formats:  Uncompressed 10-bit, pro res, and mp4. I imported the pro res files into media composer ultimate via the source browser with no problem and proceeded to edit and clean them up as needed. The problems emerged when I strted trying to export them and found that it was extremely difficult.  For one it's impossible to export interlaced on a Mac since Catalina and that's unfortunately what I have
    My question now is whether I should bother with interlaced and just go ahead and let them be progressive and see what I get.
    Any ideas there?
    Thx,
    Mary (marluc)
  • Wed, Jul 20 2022 7:11 PM In reply to
    • jef
    • Maryland
    • Posts 4,070
    • Points 49,100
    marluc:
    Ok, so from your response I surmise that someone else captured these files for you.  Is there any way you could share a small original file with us to inspect? ProRes would be best since that is what you are using.
    As for the interlace issue, I will ask my normal question:
    What is your end use for this project?  This is critical.  Converting interlace to progressive is hardly ever a good thing.  Mostly just degrees of less bad.  But sometimes you have to do it.  Other times not.  So you need to know what the final deliverable is.
    Jef
    Jef Huey
  • Wed, Jul 20 2022 7:58 PM In reply to
    In my quick test regarding the reported image aspect ratio, no digitised files involved. New Project, import a graphic and then try an export.
  • Fri, Jul 22 2022 10:05 AM In reply to
    Job ter Burg:
    Philip Kapadia:
    Ahhh of course.
