Latest post Wed, Jul 13 2022 11:58 AM by Philip Kapadia. 4 replies.
  • Tue, Jul 12 2022 5:32 PM
    • genglehardt
    • Kutztown, PA
    • Posts 83
    • Points 1,245
    Importing 4K video
    I have a Sony AX-100 4K vidoe cam recording at XAVC S 4K.  I cannot import the video files into a 1080 P project.  I then tried to create a 4K project and again the files would not import.  When drag and drop or point to the file using the import panel nothing happens.
    Should MC be able to import and convert the 4K to my 1080 format?  What video resolution settings do i need when i try to import using a 4K project?  MC version is the 2022.4.
    Camera file is an MP4 copied from the memory card.
    Dell Tower 7810 w/64 Gig ram, dual Intel E5-2 (2x24cores)storage on 18 TB G-Raid (esata), AMD W8100, Win 10x64, MC2020.10 [view my complete system specs]
    Filed under: ,
  • Tue, Jul 12 2022 5:41 PM In reply to
    Re: Importing 4K video
    Does the mp4 link? If so, you could link it and then transcode it to whatever resolution you would've used in the import. The resulting media is the same.
    Linking & transcoding is faster, as it takes advantage of modern processor architecture that importing doesn't.
    Media Composer 2022.7 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Wed, Jul 13 2022 8:25 AM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,444
    • Points 15,855
    Hello,
    for this codec you will probably need XAVC S AMA pugin from Nablet to connect directly to MC. Unfortunately, it is paid.
    https://www.nablet.com/products/plugins/avid-media-composer/xavc-s-ama-plugin/
    A free solution is probably to use DaVinci Resolve to create the desired codec.
    V.
    AVID MC2021.12, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 461.72, RAM 48GB - DDR3, BM Intensity Pro 4k - 12.1, W10 - 64bit Professional... [view my complete system specs]
  • Wed, Jul 13 2022 10:05 AM In reply to
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 381
    • Points 4,530
    I used a plugin for XAVC -S awhile ago and I do not think I paid for it - Now I see it is 89 pounds I think.  I will check and see which one I am using.  It might have been Drastic plugin.  Either way it works well.
    Symphony 2022.7- Win 10 pro (20H2),Gigabyte X299X with i9 10920X CPU, Quadro P2000,driver 51.259; 64gig memory, 1TB NV system drive, WD 4TB, BM Min Monitor... [view my complete system specs]
  • Wed, Jul 13 2022 11:58 AM In reply to
    Vilem:
    Likewise, shutter encoder is a fantastic free tool that will let you convert these video files into a format Avid can read.
    Editing Movie Magic.
    My Equipment & System Specs
    Media Composer Ultimate 2022.7 | Pro Tools Studio 2022.7 | Avid Play | Sibelius Artist 2022.7
