Latest post Fri, Jun 10 2022 3:54 AM by hbrock. 1 replies.
Page 1 of 1 (2 items)
  • Wed, Jun 8 2022 5:04 PM
    • Tentaor
    • Joined on Thu, Nov 15 2007
    • Posts 45
    • Points 510
    Export AAF with multiple framerates
    Hi! I have a project with mixed framerates. 25 and 100 FPS.
    My project is 1080 25P.
    All my videos are AMA linked.
    When I need to export an AAF to deliver to the post-studio I export my timeline as AAF with Consolidate and Embed Media (in a folder) checked. I noticed that 100FPS clips are exported as 25FPS.
    As an example: In my timeline I have 1 clip (100fps) with a 25% speed Timewarp applied to convert to 1/4 slowmotion. (100fps/4=25fps). But in resulted AAF the clip was interpreted as a 25fps and reduced 1/4 to a result if a HORRIBLE 6fps clip (25fps/4=6,25fps)
    What's wrong with my export settings?
    There are not framerate Consolidate options in the export settings?
    To solve it I'm exporting with "copy and link" option instead "consolidate and embed" AFTER previously consolidate my timeline with Consolidate/Transcode (in this window I have framerate conversion options)
    Any advice to improve my export workaround?
    Thanks!!!
    Media Composer 2022.7 MAC STUDIO MAX 64GB MAC OS 12.3.1 Monterey /// IMAC 27 LATE 2013 32 GB RAM MAC OS Catalina 10.15.7 [view my complete system specs]
  • Fri, Jun 10 2022 3:54 AM In reply to
    • hbrock
    • Bainbridge Island, WA
    • Posts 5,568
    • Points 64,850
      Moderator: MCA Mac
    Re: Export AAF with multiple framerates
    It's because you're making new media by consolidating and the frame rate is fixed on consolidated media. If you select Transcode you have the option to "Keep native frame rate" or "Convert to project frame rate".  In this case, keep the native frame rate.  Then make a linked AAF from the transcoded.exported sequence that is created when you do a transcode.  That AAF will link to the transcoded clips.
    Or you could just send your AMA media along with a AAF from your sequence.  That may or may not be appealing.
