Hi!
I am unable to import or link mp3 files in Media Composer.
If I drag the file from the finder to a bin nothing happens.
If I drag it with the ALT key pressed to link it, nothing happens either.
If I try to import it from a bin I get a message saying the file can't be imported but I can link and consolidate it. If I do that, a screen ends up with an error "The file ***** is an unknown file" and it doesn't work either
Help please!
Avid version 2022.4
Avid Link 2022.4
Is this with all .mp3 files or just one? Do the files play outside of Media Composer? Can you try importing or linking a file that you know is good?
All the Mp3 fail. All play correctly outside MC. Previously mp3 imported does not import again now.
I´m in Catalina.
I tried to reinstall without succes.
I downgraded to 2021.12.1 (MC) and 2021.12.2 (Avid Link) and Install MediaComposer Legacy Components without succes.
I´m working transcoding all MP3 to WAV with Encoder. WAV import works well.
This is a common problem in Catalina or later versions of MacOS with Media Composer.
These search results might have some more information that would help: https://bit.ly/3wmgitA
If not, I suggest you create a case on the MyAvid support portal and someone will get to you asap.
This is crazy!
I tried to create a case but my acces to the Support Portal was not active. I filled the form to activate it but it is in process yet. It´s very strange. I´have an active perpetual license with support until August
"Unlimited online technical support, billing and account help, with up to one business day response time"
Send an email to Chris Bové (chris.bove@avid.com) and Raff Condalor (raff.condalor@avid.com). They are Avid's customer advocates, and can help you.
Thank you very much. I have done what you have told me and I have been able to contact Avid support. After a 1 hour remote support session we discovered that it only failed to link converted mp3 files from a specific website. Changing the online converter has stopped failing with those files. However both Premiere and DaVinci worked perfectly with those first files (also working on Catalina)
